Tools window
Tools window Lap1994 08 Dec 02:00
  Tools window David Gowers 08 Dec 14:37
Lap1994
2008-12-08 02:00:19 UTC (over 16 years ago)
Tools window
Whats up with the tools window? See my view: All the tools can be selected pressing a key combination such as A, S, P, CTRL E blahblahblah. So, less points for it. The menu that was once was there is no more there. Less points for it. The tool options has move, by myself, to a combination of dockable dialogues because putting it on the tools windows only makes less room for the image I will edit. Less points to it. Closing that means closing the whole app. Less points to it. The minimize button that was once there is no more there. Less points for it.
Conclusion: Its points-less for me having that displayed in my desktop however I cant close or minimize that! How annoying...
David Gowers
2008-12-08 14:37:58 UTC (over 16 years ago)
Tools window
If this bothers you, hide all the tools using the 'tools' dockable. The resultant toolbox is much smaller.
Lap1994, sending any bug/suggestion in the more simple way since he had this idea
