Fwd: Re: Conversion to XGA
Fwd: Re: Conversion to XGA <sablade08@a4skyhawk.org> 07 Dec 06:01
  Fwd: Re: Conversion to XGA David Gowers 07 Dec 06:14
   Fwd: Re: Conversion to XGA Tobias Jakobs 07 Dec 17:06
2008-12-07 06:01:19 UTC (over 16 years ago)
Can I, for instance, convert a 2277x3080 pixels image to a 1024x765 (XGA) image and how should I do that?
Yes, you can:
http://docs.gimp.org/en/gimp-tutorial-quickie-scale.html
Is it possible to resize about 3,000 photos using the method listed in the tutorial as a batch process to 640 X 480 while also watermarking them and then make an additional image that is 100 X 100 from the watermarked 640 X 480? That's the link I need.
David Gowers
2008-12-07 06:14:30 UTC (over 16 years ago)
Yes, you can:
Imagemagick sounds far more suitable for that task.
http://www.imagemagick.org/Usage/resize/ http://www.imagemagick.org/Usage/annotating/
David
Tobias Jakobs
2008-12-07 17:06:06 UTC (over 16 years ago)
Am Sonntag, den 07.12.2008, 15:44 +1030 schrieb David Gowers:
Yes, you can:
Or use a Tool like Phatch:
http://photobatch.stani.be/
Regards, Tobias
