exif loss
exif loss Rinke H. 30 Nov 18:04
  exif loss Andrew 30 Nov 18:44
Rinke H.
2008-11-30 18:04:31 UTC (over 16 years ago)
exif loss
Hi list,
I have gimp 2.6 and ufraw installed on a windows 2000 sp4 machine.
Whenever I try to convert a dng file (the pentax raw file format) my exif data gets completely lost.
If I send the image from ufraw to gimp, and then save it, I get no error message at all;
if I save it directly from ufraw, I I get an error message saying: "exif buffer length 79514, too long, ignored" .
Does anybody know if there 's a sollution to this?
Is there a work-around? Can I copy my exif data back into the jpg image in an easy way?
thanks,
Andrew
2008-11-30 18:44:36 UTC (over 16 years ago)
exif loss
Rinke H. wrote:
Hi list,
thanks,
A possible workaround would be to copy the exif data from the original .dng to the converted file using exiftool.
http://www.sno.phy.queensu.ca/~phil/exiftool/
HTH
Andrew
