PS scaling looks noticeably better then Gimp's
PS scaling looks noticeably better then Gimp's smith 28 Nov 22:09
  PS scaling looks noticeably better then Gimp's David Gowers 28 Nov 23:34
  PS scaling looks noticeably better then Gimp's Ruud Amesz 29 Nov 20:51
   PS scaling looks noticeably better then Gimp's David Gowers 29 Nov 23:13
    PS scaling looks noticeably better then Gimp's Sven Neumann 01 Dec 21:09
PS scaling looks noticeably better then Gimp's giuliogiuseppecarlo@interfree.it 30 Nov 09:24
smith
2008-11-28 22:09:34 UTC (over 16 years ago)
I've noticed this on multiple occasions that when I scale pictures down in Photoshop they look noticeably better when I do the same in Gimp. The scaled down image PS leaves is sharp and crisp, while the Gimp scaled down is more blurry.
Does anybody know why this is the case and if there is any setting I am missing that would improve the quality of pictures when they they get scaled down (this is especially true for scaled down fonts that were flattened and unrecoverable).
David Gowers
2008-11-28 23:34:50 UTC (over 16 years ago)
You have omitted to mention what scaling method you used in PS and Gimp respectively.
Without this information, I can't help you with this problem.
David
Ruud Amesz
2008-11-29 20:51:50 UTC (over 16 years ago)
After scaling down an image you have to use the filter USM (unsharp mask) to sharpen your image. You did not mention if you did so.
Ruud> To: gimp-user@lists.XCF.Berkeley.EDU> From: forums@gimpusers.com> Date: Fri, 28 Nov 2008 22:09:34 +0100> Subject: [Gimp-user] PS scaling looks noticeably better then Gimp's> > I've noticed this on multiple occasions that when I scale pictures down in> Photoshop they look noticeably better when I do the same in Gimp. The scaled> down image PS leaves is sharp and crisp, while the Gimp scaled down is more> blurry. > > Does anybody know why this is the case and if there is any setting I am> missing that would improve the quality of pictures when they they get scaled> down (this is especially true for scaled down fonts that were flattened and> unrecoverable).> > > -- > smith> _______________________________________________> Gimp-user mailing list> Gimp-user@lists.XCF.Berkeley.EDU> https://lists.XCF.Berkeley.EDU/mailman/listinfo/gimp-user __________________
David Gowers
2008-11-29 23:13:12 UTC (over 16 years ago)
Are you saying that Photoshop automatically does that when you scale down?
David
2008-11-30 09:24:48 UTC (over 16 years ago)
>I've noticed this on multiple occasions that when I scale pictures down in>Photoshop they look noticeably better when I do the same in Gimp. The scaled>down image PS leaves is sharp and crisp, while the Gimp scaled down is more>blurry. Could you provide a detail of an image? E.g. scale it with photoshop telling us the method, then with gimp always with the method used, and put it ( or a crop ) of both on imageshack? And also tell us the original size of the image, and what kind of scale you have used ( eg. from 2048 to 800 )I have noticed too, comparing results with a friend of mine, somethings similar, gimp often produces more moirè effect.Btw, 2.6.2 has some problems scaling down an image, use 2.6.3 .Bye.
----------------------------------------------------------------------------Vuoi essere presente online? Vuoi dare voce alla tua attivita`? Acquista un dominio su domini.interfree.it.A partire da 18,59 euro----------------------------------------------------------------------------
2008-12-01 21:09:42 UTC (over 16 years ago)
They are probably not really applying unsharp mask, but there are interpolation methods that do something similar. The Lanczos method in GIMP has this quality. The Sinc kernel used for interpolation works somewhat similar to what Unsharp Mask does. Still it is sometimes necessary to do additional sharpening after scaling.
