GIMP 2.6.1 from Macports, strange window behavior
GIMP 2.6.1 from Macports, strange window behavior Michael Hernandez 13 Oct 17:39
  GIMP 2.6.1 from Macports, strange window behavior Bettina Karena Lechner 13 Oct 19:33
   GIMP 2.6.1 from Macports, strange window behavior Michael Hernandez 13 Oct 23:19
   GIMP 2.6.1 from Macports, strange window behavior Michael Hernandez 13 Oct 23:31
    GIMP 2.6.1 from Macports, strange window behavior Hedley Finger 14 Oct 05:25
     GIMP 2.6.1 from Macports, strange window behavior Chris Mohler 14 Oct 06:01
Michael Hernandez
2008-10-13 17:39:33 UTC (over 16 years ago)
Hey all,
I have this strange issue with the latest GIMP - things from menus and some child-windows (not sure if that's the right name for these, but there are mini-windows that GIMP pops up to allow you to select modes from a drop down, for example) are shown either off my screen or behind a tool window. The problem is that I can't move the window out of the way to get to the mini-window underneath, and I can't see things sometimes that are off the visible area (sometimes things pop up halfway out of the area and I can drag them back in).
I'm not sure if this is related to X11 or if it's a GIMP bug (or maybe even a macports port bug, but since it builds and installs fine I think the port from macports is the cause).
Is anyone else seeing this strange behavior? Is there something I can do to fix it?
I am running GIMP 2.6.1 compiled from Macports on a macbook pro 15" with X 2.3.1
Thanks!
--Mike H
2008-10-13 19:33:45 UTC (over 16 years ago)
Hi mike!
try using the gimp.dmg from here: http://gimp.lisanet.de/Website/Download.html
my installation is working fine (same environment as yours)
maybe it's an macport problem, joy!
tina
Von: Michael Hernandez
Datum: Mon, 13 Oct 2008 11:39:33 -0400 An: X11 List Mailing , GIMP User Mailing List
Betreff: [Gimp-user] GIMP 2.6.1 from Macports, strange window behavior
Hey all,
Thanks!
--Mike H
Michael Hernandez
2008-10-13 23:19:38 UTC (over 16 years ago)
I'll try that now and report back!
Thanks! :)
--Mike
On Oct 13, 2008, at 1:33 PM, Bettina Karena Lechner wrote:
Hi mike!
tina
Hey all,
Thanks!
--Mike H
Michael Hernandez
2008-10-13 23:31:08 UTC (over 16 years ago)
This works nicely, thanks so much.
--Mike
Hi mike!
tina
Hey all,
Thanks!
--Mike H
Hedley Finger
2008-10-14 05:25:38 UTC (over 16 years ago)
I feel as though I have invited everyone to a feast and then locked myself outside in the rain while the party carries on. I just *cannot* get the convert_ASE_to_GPL.py to work even after:
@ downloading and installing the ActiveState Python interpreter over the AS Python already installed (uninstall/install), @ placing convert_ASE_to_GPL.py in both my personal and executable plug-ins directories (separately and simultaneously) -- C:\Documents and Settings\Hedley Finger\.gimp-2.6\plug-ins C:\Program Files\Gimp20\lib\gimp\2.0\plug-ins
Python is installed okay because the script immediately gets the Python icon. When double-clicked a CLI window briefly opens showing that the interpreter is having a go. But it just won't work. Nothing appears in the menus, and Help > Plug-in Browser shows nothing under either Convert ... or Import ... . Aaaaargghhhh!
Is there anybody on the list using Gimp 2.4.1 to 2.6.1 on Windows who has made this work? What did you do? Does this directory have anything to do with it: C:\Program Files\Gimp20\lib\gimp\2.0\interpreters ? There was a mention in this thread of compiling Gimp with the Python bindings. Another clue? Does anybody know whether the binary executable for Windows is compiled with the Python bindings?
Regards, Hedley
Gimp 2.6.1
Windows XP SP3
Hedley Finger
28 Regent Street Camberwell VIC 3124 Australia Tel. +61 3 9809 1229 Fax. (call phone first) Mob. (cell) +61 412 461 558
Email. "Hedley Finger"
Chris Mohler
2008-10-14 06:01:16 UTC (over 16 years ago)
Hi Hedley,
Windows is *not* my primary OS, but I did get it to work with 2.6.1 under windows XP two days ago.
I installed python first then these packages: pycairo-1.4.12-1.win32-py2.5.exe, pygobject-2.14.1-1.win32-py2.5.exe, pygtk-2.12.1-2.win32-py2.5.exe, gimp-2.6.1-i686-setup.exe. A reboot (for luck), and it showed up in the plug-in browser after launching gimp 2.6.1.
I placed the python script in C:\Documents and Settings\\.gimp-2.6\plug-ins\.
Hopefully you can get it working based on the above but fear not: the party is still going on - still plenty of time to get inside, dry yourself off, and sidle up to the bar :)
Chris
