I need to know
5 of 6 messages available
I need to know Bimal Rekhadiya 09 Oct 18:38
  I need to know Martin Nordholts 09 Oct 19:18
mailman.223377.1223572718.1... 07 Oct 20:19
  I need to know Bernd Weber 10 Oct 00:08
   I need to know Chris Mohler 10 Oct 00:11
   I need to know Kevin Cozens 10 Oct 20:33
Bimal Rekhadiya
2008-10-09 18:38:17 UTC (over 16 years ago)
I need to know
Hi
I am a webmaster. I like GIMP. I am creating web interface sometimes.
But I am using PhotoShop, I cannot use GIMP because in every interface I add demo logo and apply some effects like Drop Shadow, Outer Glow etc. And later the buyer want to apply that all effect to his original logo, because it looks nice on that theme.
In PhotoShop I just open that file and select text tool and change text, and done. But in GIMP I have to write that name and trying to apply same effect and matching with that logo, and it takes 30 or more min.
So, I want to ask you that is there any future plan to add something like that feature? I want a feature that can change text after apply Drop Shadow, Outer Glow, Inner Shadow etc.
Martin Nordholts
2008-10-09 19:18:34 UTC (over 16 years ago)
I need to know
Hi
Yes this is planned. Don't hold your breath though as it will take quite a while before we reach there, but it is absolutely planned and we are slowly but steadily making progress.
BR, Martin
Bernd Weber
2008-10-10 00:08:53 UTC (over 16 years ago)
I need to know
I think all these fine things could be produced with scripts or plug-ins. I do work as webmaster, too. I am not a fan of scheme or lisp. I rather use perl-gimp. I like the concept of the procedural database very much. Unfortunately perl-gimp seems not being supported very much, the last time. I made a plug-in for buttons giving the base structure and correct dimensions for printing. You only have to insert am image afterwards as your main motif. Or I made a plug-in for using gocr out from gimp. I doubt whether photo shop has this extendability. But photo shop comes with a lot of features ready to use. People who don't like to write a program first might be better of with photo shop. I prefer GIMP.
But about procedural data-base: When I want to insert a path I have to use PF_STRING. I didn't find a feature from which you can get a file chooser dialog. That's a little bit nasty. Or is there an opportunity and I didn't find it?
Message: 7
Date: Thu, 9 Oct 2008 22:08:17 +0530 From: "Bimal Rekhadiya"
Subject: [Gimp-user] I need to know
To: gimp-user@lists.XCF.Berkeley.EDU Message-ID:
Content-Type: text/plain; charset=ISO-8859-1
Hi I am a webmaster. I like GIMP. I am creating web interface sometimes.
-- >From Bimal J Rekhadiya http://www.loyalindia.com http://www.brcreation.com Life is not measured by the number of breaths we take... But by the moments that take our breath away....! ------------------------------ Message: 8 Date: Thu, 09 Oct 2008 19:18:34 +0200 From: Martin Nordholts Subject: Re: [Gimp-user] I need to know To: Bimal Rekhadiya Cc: gimp-user@lists.XCF.Berkeley.EDU Message-ID: Content-Type: text/plain;
Hi
BR, Martin
Chris Mohler
2008-10-10 00:11:15 UTC (over 16 years ago)
I need to know
Use PF_FILE....
Chris
Kevin Cozens
2008-10-10 20:33:23 UTC (over 16 years ago)
I need to know
I have been meaning to release a new version of the gimp-perl package for some time now. I haven't gotten around to reading up on how to package the contents of the Subversion repository so that a standard build process (ie. cpan) can be used to install the binding.
