Make transparent layer invisible
15 of 15 messages available
Make transparent layer invisible Adonj Adonj 02 Oct 21:29
  Make transparent layer invisible Michael J. Hammel 02 Oct 21:44
  Make transparent layer invisible bgw 02 Oct 22:03
Make transparent layer invisible Adonj Adonj 02 Oct 22:03
  Make transparent layer invisible bgw 02 Oct 22:08
Make transparent layer invisible Adonj Adonj 02 Oct 22:16
  Make transparent layer invisible Patrick Horgan 02 Oct 23:20
  Make transparent layer invisible Michael J. Hammel 03 Oct 01:02
   Make transparent layer invisible Sven Neumann 03 Oct 14:12
    Make transparent layer invisible Olivier Lecarme 03 Oct 14:52
     Make transparent layer invisible David Gowers 03 Oct 15:33
Make transparent layer invis ible? Adonj Adonj 03 Oct 03:23
  Make transparent layer invisible? Michael J. Hammel 03 Oct 05:46
Make transparent layer invis ible? Adonj Adonj 03 Oct 04:13
Make transparent layer invis ible? Adonj Adonj 03 Oct 05:08
Adonj Adonj
2008-10-02 21:29:45 UTC (about 17 years ago)
Hi there,
Can the transparent layer which is represented by the gray squares be made invisible?
Thanks, Adonj
__________________
Michael J. Hammel
2008-10-02 21:44:00 UTC (about 17 years ago)
No. The checkboard pattern is configurable (see Preferences/Display) but the pattern or color you choose is not actually a layer. It's just a way of showing where in the image some level of transparency exists through the existing layers. You can't see, for example, your desktop through that transparent area, however.
Adonj Adonj
2008-10-02 22:03:07 UTC (about 17 years ago)
That's exactly what I was looking for! To see the desktop through that transparent area. Therefore I see there is no possibility of doing so while using Gimp? Is that only achievable in other animation software and may be as well in Gimp in a future version?
Adonj
__________________
bgw
2008-10-02 22:03:28 UTC (about 17 years ago)
Adonj Adonj wrote:
Hi there,
Thanks, Adonj
__________________
bgw
2008-10-02 22:08:17 UTC (about 17 years ago)
Adonj
__________________
Adonj Adonj
2008-10-02 22:16:29 UTC (about 17 years ago)
If I export it to png it wouldn't be an animation! I'm sorry I obviously overlooked mentioning my intention.
Adonj
__________________
Patrick Horgan
2008-10-02 23:20:44 UTC (about 17 years ago)
Do animated gifs support transparency? I've never tried it...oh, wait, yes I did, just the other day I made an animated gif icon with transparency for someone's web site. Funny, I answered my own question:)
Patrick
Michael J. Hammel
2008-10-03 01:02:45 UTC (about 17 years ago)
You can preview the transparency by using the GAP player (Filters->Animation->Playback). When the player dialog opens, right click on the canvas area and choose "Detach". Then drag the canvas area over your desktop. The animation will playback over your desktop with transparency rendered. It may not be a perfect render, but it should work.
Saving to PNG preserves full transparency but I don't think PNGs support animation (use MNG instead, I believe). I could be wrong about that as I don't do much with animations.
Saving as GIF will reduce the palette to 256 colors and reduce multiple-levels of transparency (re: 0%-100%) to a single state of transparency (pixels are either fully transparent or they are not).
Animated GIFs play fine in web browsers. PNGs (non-animated) with transparency work well in modern browsers but suck in older versions of MSIE. That's the browsers fault, not PNGs fault.
Adonj Adonj
2008-10-03 03:23:07 UTC (about 17 years ago)
I use the GAP player when I need to. Saving to PNG will have layers merged or flattened. That doesn't work for animations. Saving as GIF is my final result.
To demonstrate the problem I'm having: In my animation I have two identical frames of an object surrounded by a transparent background which is represented by small gray squares. If I move the object slightly in one frame, then play the animation, and detach the image, then drag the image which is now stepping from one frame to the other to the desktop screen, the area around the object which has had the object displaced, shows some of the gray squares each time the image steps to this displaced image frame.
__________________
Adonj Adonj
2008-10-03 04:13:06 UTC (about 17 years ago)
Here is a desktop capture of the animation dragged to it:
ftp://www3.sympatico.ca/transparency%20showing%20example.jpg
Adonj
__________________
Adonj Adonj
2008-10-03 05:08:03 UTC (about 17 years ago)
Sorry about the previous link, it was incorrect. This one should do it:
http://www3.sympatico.ca/adly1/example.htm
Adonj __________________
Michael J. Hammel
2008-10-03 05:46:04 UTC (about 17 years ago)
Yeah, you have to save as MNG instead, I'm pretty sure. But MNG probably isn't supported in web browsers all that well. I assume you're trying to do this for the web or you wouldn't even consider GIF animations.
Saving as GIF is my final result. To demonstrate the problem I'm having: In my animation I have two identical frames of an object surrounded by a transparent background which is represented by small gray squares. If I move the object slightly in one frame, then play the animation, and detach the image, then drag the image which is now stepping from one frame to the other to the desktop screen, the area around the object which has had the object displaced, shows some of the gray squares each time the image steps to this displaced image frame.
Yeah. As far as I know, that's how it works.
2008-10-03 14:12:42 UTC (about 17 years ago)
That plug-in has nothing to do with GAP, the GIMP Animation Plug-In. It is bundled in the standard set of plug-ins that ship with GIMP.
Olivier Lecarme
2008-10-03 14:52:32 UTC (about 17 years ago)
By the way, will GAP be adapted to GIMP 2.6, and when? I really hope so!
David Gowers
2008-10-03 15:33:21 UTC (about 17 years ago)
Hi Olivier,
What do you mean? I used it with 2.6 today. No adaptation needed.
Do you mean a Windows binary of GIMP-GAP? There should be no reason that you cannot use the currently available one.
HTH, David
