Perl-o-tine filter and JPEG image quality
3 of 4 messages available
Perl-o-tine filter and JPEG image quality Tom Williams 29 Sep 04:03
20030929191629.AE476102D6@l... 07 Oct 20:15
  Perl-o-tine filter and JPEG image quality Christopher Hicks 29 Sep 21:14
   Perl-o-tine filter and JPEG image quality Sven Neumann 29 Sep 23:49
Tom Williams
2003-09-29 04:03:28 UTC (about 22 years ago)
Hi! Is there a way to control the JPEG image quality settings for the JPEG images that can be generated by the "Perl-o-tine" filter? I'm finding the quality of the JPEGs that are generated by the filter are of lower quality than the source JPEG or XCF file used as the source for the "Perl-o-tine" filter.
I'm using Gimp 1.2.5 on Slackware 8 Linux.
Thanks!
Peace...
Tom
Christopher Hicks
2003-09-29 21:14:45 UTC (about 22 years ago)
We're having the same problem with gimp on Red Hat. I would love it if someone would take the time to update this feature and I'm sure a lot of the end users would particularly appreciate it too. Our designers end up doing these things by hand or using external tools which seems like such a waste since perl-o-tine is so close to making this really pain-free to do entirely within gimp.
2003-09-29 23:49:22 UTC (about 22 years ago)
Christopher Hicks writes:
Of course there's a way. Modify the source of perlotine so that it doesn't call the general gimp_file_save() function but uses file_jpeg_save() explicitely. The latter function gives you fine-grained control over the JPEG save parameters such as the quality setting.
