Exotic zoom ratios in 1.3.*
Exotic zoom ratios in 1.3.* Eric Pierce 28 Sep 07:21
  Exotic zoom ratios in 1.3.* Sven Neumann 28 Sep 14:52
Eric Pierce
2003-09-28 07:21:07 UTC (over 21 years ago)
I notice that when I use the zoom tool, I get really exotic zoom ratios like 67:189 for example(see View>Zoom). And that's fine, but if i then try to use the zoom keyboard shortcut, it zooms in really small increments.
Is this an intended effect?
Any way to get it to zoom in larger increments?
Thanks, Eric Pierce
2003-09-28 14:52:43 UTC (over 21 years ago)
"Eric Pierce" writes:
The function that is called for the key shortcuts could be made smarter. Perhaps you can file a bug report about it so we don't forget to handle this issue.
