gimp 2.2 -> 2.4, python-fu: what's the difference?
| gimp 2.2 -> 2.4, python-fu: what's the difference? | Kristian Rink | 26 Aug 14:07 |
| gimp 2.2 -> 2.4, python-fu: what's the difference? | Sven Neumann | 26 Aug 21:04 |
| gimp 2.2 -> 2.4, python-fu: what's the difference? | Kristian Rink | 26 Aug 21:43 |
| gimp 2.2 -> 2.4, python-fu: what's the difference? | Sven Neumann | 26 Aug 22:06 |
| gimp 2.2 -> 2.4, python-fu: what's the difference? | Joao S. O. Bueno | 27 Aug 00:09 |
| gimp 2.2 -> 2.4, python-fu: what's the difference? | Kristian Rink | 27 Aug 09:34 |
| gimp 2.2 -> 2.4, python-fu: what's the difference? | Joao S. O. Bueno | 27 Aug 00:06 |
Folks;
dealing with python-fu quite a while ago (early gimp 2.2, I guess), I haven't dealt with this for quite a while, just to stumble across it once again by now, figuring out a few things obviously changed:
- Initially, I used to write up a script, dump it to .gimp/plug-ins, start the Gimp and find its procedures using the gimp Procedure Browser searching for "python-fu". It's not the case anymore now, despite the file being still in .gimp-2.4/plug-ins/ and being marked executable and the code structure not having changed.
- Likewise, I used something like this to register the script with The Gimp:
register(
   ”python_fu_mergesofned”,
   ”merge picture with a blurred version of itself”,
   ”Kristian Rink”,
   ”Kristian Rink”,
   ”2005?,
   ”/Python-Fu/z428/LayeredSoftness”,
   ”RGB*,GRAY*”,
mergesofned)
... which obviously doesn't work again as the /Python-Fu menu is gone and I fail to relocate the menu entry elsewhere, no matter what I enter as menu path (/Filters/Python/... failed...). What to do here? Is there some pointer outlining how to deal with python scripts in Gimp 2.4?
Any help / hints greatly appreciated. :)
Cheers & best regards, Kristian
Are you sure that you have the GIMP Python extension installed at all?
Hi there;
Well... to put it this way: As sure as can be:
- The package seems to be installed in the appropriate version matching my Gimp:
kr@kassiopeia:~ > dpkg -l|grep gimp-python ii gimp-python 2.4.6-1ubuntu1~hardy1 Python support and plugins for GIMP
- In Gimp, there is an "Extras" -> "Python-Fu" menu which, so far, just contains a "console".
- Using the "Procedure browser" querying for python-fu leaves me finding a few entries, yet none of these provided by my own scripts...
I actually would question my installation if it wasn't for these things... Could anything still be wrong here? Invoking the python console from within Gimp also works well, same as does "import gimpfu" in the python console. Anything else I could be overlooking so far? Platform is Ubuntu 8.04 by the way...
Thanks in advance and best regards, Kristian
It should just work then. python-fu in GIMP 2.4 introduced a slightly changed syntax for registering python scripts, but the API was kept backward-compatible, so your old scripts should just continue to work.
On Tuesday 26 August 2008, Kristian Rink wrote:
Folks;
register(
”merge picture with a blurred version of itself”, ”merge picture with a blurred version of itself”, ”Kristian Rink”,
”Kristian Rink”,”2005?, ”/Python-Fu/z428/LayeredSoftness”, ”RGB*,GRAY*”,
[],mergesofned)
Hi Kristian -
there are no comaptibility changes in python-fu from gimp-2.2 to gimp-2.4
You should watch the output of GIMP to the terminal to see if any errors (like a syntax error due to a missplaced punctiation character) is happening. Otherwise, as you see no "python" or "python-fu" entrie son you rmenus at all - it looks like you simply don-? have gimp-python installed for your new gimp. (If ther eis no python-fu entry under your "xtns" menu on the toolbox, then it is really not there)
If you are on Linux, just look for a package named "gimp-python" or similar.
That said, an easy way to find out plug-ins when you don't know where in the menus they are, is to use the "plug-in browser" (which on 2.4 lives on the "Xtns" menu).
js ->
Indeed -
Kristian, jsut start GIMP from the terminal and check for an error
output.
You might just try to load your script with straight with python, to
check for syntax errors, since if there is a python syntax error,
gimp will just spill out an obscure uninformative error  message
instead of the traceback of the script.
Hi Joao;
and first off, thanks a bunch for your pointer. :)
Joao S. O. Bueno wrote: [..]
You might just try to load your script with straight with python, to check for syntax errors, since if there is a python syntax error, gimp will just spill out an obscure uninformative error message instead of the traceback of the script.
Actually yes, that did resolve my problems. Seems copying the script across the machines somehow messed my charset up so python complained about illegal characters while starting up. Thanks loads for your help on that. :)
Cheers, Kristian
