gimprc gamma and gamma_convert
gimprc gamma and gamma_convert Robin Rowe 07 Sep 07:32
  gimprc gamma and gamma_convert Sven Neumann 08 Sep 09:47
gimprc gamma and gamma_convert Robin Rowe 08 Sep 04:42
Robin Rowe
2003-09-07 07:32:37 UTC (over 21 years ago)
Hi. I'm looking at the gimprc file and wondering how GIMP handles gamma.
# Set the gamma correction values for the display # 1.0 corresponds to no gamma correction. For most displays, # gamma correction should be set to between 2.0 and 2.6 # Run the utility "gamma_correct" to determine appropriate values # for your display.
# One important item to keep in mind: Many images that you might # get from outside sources will in all likelihood already be # gamma-corrected. In these cases, the image will look washed-out # if the gimp has gamma-correction turned on. If you are going # to work with images of this sort, turn gamma correction off # by removing this line, or setting the values to 1.0. # gamma-correction 1.0
# gamma-correction 2.0
(gamma-correction 1.0)
This came from a GIMP 1.2.3 Windows gimprc.
Setting a gamma value of 2.2 or 1.0 in gimprc had no visible effect. How is this feature enabled?
Is there a gamma setting somewhere in the preferences dialog?
Where is the gamma_correct tool mentioned in gimprc?
Thanks,
Robin --------------------------------------------------------------------------- Robin.Rowe@MovieEditor.com Hollywood, California www.CinePaint.org Free motion picture and still image editing software
Robin Rowe
2003-09-08 04:42:38 UTC (over 21 years ago)
Thanks,
2003-09-08 09:47:36 UTC (over 21 years ago)
"Robin Rowe" writes:
The short answer is that the gimprc gamma setting is ignored. The longer answer is that there are a some plug-ins that ask GIMP for this value and might choose to do something with it. But since it is ignored in general, these plug-ins can't probably be doing the right thing.
