GEGL_PROPERTY_TYPE
GEGL_PROPERTY_TYPE geert jordaens 11 Jun 16:19
geert jordaens
2005-06-11 16:19:20 UTC (almost 20 years ago)
GEGL_PROPERTY_TYPE
after Mitch telling me "gegl-property" was a "pad" I assumed because "gegl-property" had both input/output related stuff it was a "path" between nodes.
Pippin explained me that I was totaly off and that actualy "property" was a "pad" with variable properties and that it would probably better to derive pad from properties. (Hope I've got this right so far).
I would like to propose as an alternatieve to GEGL_PROPERTY_TYPE the GEGL_ATTRIBUTE_TYPE in order to not have naming conflicts with the standard glib property. (attribute was the best synonym i could imagine).
GEGL_ATTRIBUTE_TYPE would be derived from GEGL_OBJECTYPE_TYPE. GEGL_PAD_TYPE would be derived from GEGL_ATTRIBUTE_TYPE and implement the interface GEGL_TYPE_VISITABLE.
If this sounds ok I would not mind refactoring this.
Geert
