Tile sizes...
Tile sizes... Joao S. O. Bueno Calligaris 17 Sep 19:33
Tile sizes... Sven Neumann 17 Sep 19:49
Tile sizes... Daniel Rogers 17 Sep 20:32
Tile sizes... Øyvind Kolås 17 Sep 20:45
2004-09-17 19:33:57 UTC (over 20 years ago)
Tile sizes...
I was just wondering...tiles sed in the GIMP are 64x64 bit right? I suppose that is the default value for GEGL as well.
So here are my questions: when was this sized picked up? Is it machinne dependant? (I mean, one thing are the 486's from when the GIMP came into existence, other thing are today's Pentium IV, and another thing will be tomorrow 1024bitUltraWideX Cell-Quantum-Laser Microprocessors.
And the other question is : does GEGL have provisions for other tile sizes? I guess so.
JS ->
2004-09-17 19:49:25 UTC (over 20 years ago)
Tile sizes...
"Joao S. O. Bueno Calligaris" writes:
Right. It's defined in a single place though. If you want to play with other sizes, give it a try. The only problem is that you won't be able to read XCF files you've written with a GIMP compiled with other tile sizes. With some effort this could be handled in the XCF routines though.
I don't think there's a tile-based pixel storage module in GEGL yet but it was planned to add that. I might be wrong though.
So what? I mean how is the CPU type related to the tile size? Well, I know there are relations but I think that it is up to you to explain them to us. After all it's you who brought this topic up again.
BTW, I've played with other tile sizes some months ago and came to the conclusion that 64x64 is still a reasonable choice.
Daniel Rogers
2004-09-17 20:32:58 UTC (over 20 years ago)
Tile sizes...
Strickly speaking the classes that describe tiles are not written yet, though to hypotetically answer your question, there is no "default" tile size built into gegl. The tile size is set on a per image basis.
I don't know the origin of this size.
Yes. It will.
Dan
Øyvind Kolås
2004-09-17 20:45:15 UTC (over 20 years ago)
Tile sizes...
GEGL should make it possible to do tilebased processing,. or scanline based processing, or even plain stupid frame based (like gggl). Applications using GEGL will not access the internal data structures (partitioning in data into tiles / scanlines etc. should be considered private.
It might even be possible to merge tile based / frame based etc. amongst the nodes/op's at the GEGL level,. but this is IMO a private implementation detail that the hosting application shouldn't need to care about.
/pippin
