simple suggestion for the UI
simple suggestion for the UI devvv 12 Jul 15:36
  simple suggestion for the UI vabijou2 12 Jul 16:38
   simple suggestion for the UI David Odin 12 Jul 17:23
  simple suggestion for the UI Martin Nordholts 13 Jul 16:18
devvv
2008-07-12 15:36:17 UTC (over 16 years ago)
hello developers,
I tried the svn trunk some days ago and I wanted to suggest that if someone double clicks the main window (the one that is displayed if no other image is opened) the "new image" dialog should open.
thanks for your work on GIMP,
best regards, bernhard stockmann
vabijou2
2008-07-12 16:38:33 UTC (over 16 years ago)
Bernhard Stockmann wrote:
...I wanted to suggest that if
How would you propose for this functionality be discovered by the user?
David Odin
2008-07-12 17:23:32 UTC (over 16 years ago)
A message in the status bar would do it.
Martin Nordholts
2008-07-13 16:18:41 UTC (over 16 years ago)
Hi
Thanks for the suggestion!
That window is planned to be filled with an on-demand tip system in 2.8. It is not yet clear exactly how that will look or work, but since a double-click might not be as natural then as it is now, we should wait with doing that change until the fate of the no-image-window is clearer.
Doing it for 2.6 risks a regression if we need to remove it in 2.8 again.
Best regards, Martin Nordholts
