problem solved
RE SIZABLE TOOLBAR and ICONS REARRANGEMENT. pampryl 10 Jul 13:46
  RE SIZABLE TOOLBAR and ICONS REARRANGEMENT. Martin Nordholts 10 Jul 18:18
   RE SIZABLE TOOLBAR and ICONS REARRANGEMENT. Bill Skaggs 10 Jul 18:57
    problem solved pampryl 11 Jul 13:23
pampryl
2008-07-10 13:46:13 UTC (over 17 years ago)
In the Gimp, there is a toolbar which contains exclusively icons.
These icons display a tooltip when the mouse hovers on them : "Select rectangular regions", "Add text to the image", etc ...
I am interested in the toolbar's ability to get automatically resized along with the panel which contains it : when the panel is resized, the toolbar is also resized and the icons inside are reorganised on a number of lines and columns which varies according to the room given to the toolbar in width and height.
To make things clear : suppose you reduce the width of the panel, then the toolbar's width is also reduced and then fewer icons can be displayed on a single line. So the right-hand icons are shifted from line N to line N+1 on the left side.
Is this kind of toolbar a specific component of GTK+ ? Where can I find the source code of this component either in GTK+ or the Gimp ?
I am waiting for your suggestions with great impatience.
Martin Nordholts
2008-07-10 18:18:46 UTC (over 17 years ago)
Hi
The toolbox logic is implemented in GIMP, have a look in app/widgets/gimptoolbox.c and more specifically gimp_toolbox_size_allocate().
- Martin
Bill Skaggs
2008-07-10 18:57:01 UTC (over 17 years ago)
The code makes use of a widget called GtkWrapBox, from which two other widgets are derived, GtkHWrapBox and GtkVWrapBox. In spite of the names, they are not part of Gtk, only of Gimp. (I believe the code was written with the intention of adding it to Gtk, but wasn't accepted.)
You can find the code for the widgets in the app/widgets directory of the Gimp source, if you are interested.
-- Bill
pampryl
2008-07-11 13:23:14 UTC (over 17 years ago)
problem solved
Thanks a lot Bill, the GtkWrapBox is exactly what I need.
Pampryl
