patterns in Gimp
patterns in Gimp Andrei Simion 07 Jul 18:41
  patterns in Gimp David Gowers 08 Jul 02:45
  patterns in Gimp Kevin Cozens 08 Jul 05:24
Andrei Simion
2008-07-07 18:41:10 UTC (almost 17 years ago)
patterns in Gimp
I know that Gimp patterns are actually files having the extension .pat. I want to upgrade from an older version of Gimp (1.2) to 2.4.
When applying a pattern called 'GIMP Pattern #1' in 1.2 and 2.4 it does not produce the same result. I'd like to know where do the patterns of this type reside. I mean I could find the pattern files directory, but there are no patterns of type 'Gimp Pattern #' neither on 1.2 nor on 2.2.
If there's a mapping between these patterns and the pattern file names, I'd be glad if you could let me know. If these patterns don not correspond to pattern files, then the question is if they create the same image with the newer versions of the Gimp. According to my tests they are not.
Andrei
David Gowers
2008-07-08 02:45:39 UTC (almost 17 years ago)
patterns in Gimp
names like "gimp pattern #1" are shown in gimp when more than one pattern has the same name ('gimp pattern' is the default pattern name when saving.). Most likely, your pattern was in a specific directory, that used to be included in the list of directories to look for patterns in. compare your preferences relating to patterns for 1.2 and 2.4.
Andrei
Kevin Cozens
2008-07-08 05:24:44 UTC (almost 17 years ago)
patterns in Gimp
The standard pattern files which ship with GIMP are stored in /usr/share/gimp/2.0/patterns on a Linux machine. You can pick a pattern from the list, right click and say "Open pattern as image" to find out its actual file name.
