international chars in Gimp
international chars in Gimp Andrei Simion 26 Jun 18:29
  international chars in Gimp Alexia Death 27 Jun 19:46
  international chars in Gimp Bill Skaggs 27 Jun 19:59
  international chars in Gimp Chris Mohler 27 Jun 20:57
  international chars in Gimp Axel Wernicke 28 Jun 00:02
Andrei Simion
2008-06-26 18:29:32 UTC (almost 17 years ago)
Does Gimp support German characters. I work on Mac and I want to add text on an image. I cannot copy/paste the character Ü because Gimp uses its own clipboard, so I have to somehow type it in. What I can do?
Regards, Andrei
Alexia Death
2008-06-27 19:46:30 UTC (almost 17 years ago)
AFAIK it does as long as your font has gylphs for them.
Can't you just type it in from your keyboard? I don't know about Mac but neither on Linux nor Windows international characters, and my language has a few specific ones, pose no problem.
Best, Alexia
Bill Skaggs
2008-06-27 19:59:27 UTC (almost 17 years ago)
The text editor has its own copy/paste, and I believe you should be able to paste your text there. Have you tried this? It is also possible to use "input methods" to type nonstandard characters.
-- Bill
Chris Mohler
2008-06-27 20:57:15 UTC (almost 17 years ago)
On a mac, just press option-u or option-shift-u...
Chris
Axel Wernicke
2008-06-28 00:02:12 UTC (almost 17 years ago)
Am 26.06.2008 um 18:29 schrieb Andrei Simion:
of course you can use the clipboard. Just copy on the Mac side by pressing Command+C and paste on the X11 (GIMP) side with CTRL+V
It's just that X11 uses CTRL instead of Command.
Works here on 10.5 with GIMP 2.4.3
Greetings, lexA
Andrei
