EXIF data missing after jpg save
12 of 13 messages available
EXIF data missing after jpg save Jim Sabatke 03 Jun 20:15
  EXIF data missing after jpg save Bill Skaggs 03 Jun 23:20
   EXIF data missing after jpg save Jim Sabatke 04 Jun 20:07
    EXIF data missing after jpg save Omari Stephens 04 Jun 20:17
     EXIF data missing after jpg save Jim Sabatke 04 Jun 21:13
    EXIF data missing after jpg save Paka 05 Jun 13:25
     EXIF data missing after jpg save Akkana Peck 05 Jun 18:52
     EXIF data missing after jpg save Sven Neumann 05 Jun 19:22
      EXIF data missing after jpg save Omari Stephens 05 Jun 19:35
       EXIF data missing after jpg save Jim Sabatke 06 Jun 01:34
   EXIF data missing after jpg save Nils Philippsen 07 Jul 09:53
mailman.193885.1212686502.1... 07 Oct 20:26
  EXIF data missing after jpg save Plinnell 09 Jun 17:44
Jim Sabatke
2008-06-03 20:15:18 UTC (over 16 years ago)
It seems that in 2.4.6 that exif data are missing when saving as a compressed jpg. They are not missing on jpgs with no compression.
I noticed on my pic site that the data were not there and after a lot of trial and error and following a few help screens from the pic site's help, that this was happening.
Is this intentional?
TIA,
Jim
Bill Skaggs
2008-06-03 23:20:48 UTC (over 16 years ago)
There is no such thing as a jpg with no compression, so it is pretty much impossible to make sense of what you are saying. It would be helpful if you would describe the actions you took and the error messages you received in a more concrete way. What were the settings you used when saving as jpg? What were the messages that told you whether or not exif data is present?
-- Bill
Jim Sabatke
2008-06-04 20:07:28 UTC (over 16 years ago)
-- Bill
OK, I'm processing Nikon D200 NEF (RAW) photos with gimp and ufraw. ufraw shows the exif data properly.
When I edit the photo in gimp and go to save with the standard settings, the exif data do not show up on my pbase website. This is a new behavior as exif data have always shown up before.
I looked at the help on the pbase site and it said most of the problems saving exif data come from high compression.
So, I re-edited a photo and saved it. On the the "Save as JPEG" screen "Save EXEF data" was checked.
On the "Subsampling:" drop box, I selected "1x1,1x1,1x1 (best quality).
Then I saved and the exif data showed on my pbase photo.
I was mistaken that I changed the compression. It was still at 85.
Hope this helps,
Jim
Omari Stephens
2008-06-04 20:17:14 UTC (over 16 years ago)
Jim Sabatke wrote:
-- Bill
Is the EXIF data not visible in the first case with a tool designed specifically for that purpose, such as metacam?
--xsdg
Jim Sabatke
2008-06-04 21:13:50 UTC (over 16 years ago)
Omari Stephens wrote:
Jim Sabatke wrote:
-- Bill
--xsdg
I couldn't find metacam anywhere, but a search through freshmeat.net showed the program jhead. Jhead did indeed find the exif data in the photo that did NOT display exif data in my album. Since the timing on this issue coincided exactly with compiling and installing gimp 2.4.6, I assumed too quickly that a bug had been introduced. That is not the case. Apparently the gallery program has changed in some way that requires a different setting on saving jpegs.
Sorry for the confusion cause and thanks for your help.
Jim
Paka
2008-06-05 13:25:23 UTC (over 16 years ago)
* Jim Sabatke [06-04-08 14:09]:
the opensuse team that is maintaining gimp/ufraw does not believe that exif data is important to the project and do not include support for exif. I questioned stbinner at suse dot de several years ago (iirc) and was imformed. Perhaps several questions/comments from different users would convince them otherwise. Maintainers names appear in the changelog comments.
I am assuming that my memory is not failing and you do/did use opensuse?
Akkana Peck
2008-06-05 18:52:40 UTC (over 16 years ago)
Paka writes:
If they can't be persuaded, Jim might want to look into jhead's -te option, which copies exif from one file to another, so you can "put back" exif that's been stripped.
...Akkana
2008-06-05 19:22:42 UTC (over 16 years ago)
Easy enough to copy the plug-in binary from a compatible distribution that compiles GIMP with Exif support enabled.
Omari Stephens
2008-06-05 19:35:05 UTC (over 16 years ago)
Are you all following a red herring? I think Jim said, in his response to my email, that the EXIF data always exists after the JPEG has been saved from the GIMP.
--xsdg
Jim Sabatke
2008-06-06 01:34:32 UTC (over 16 years ago)
--xsdg
I always compile gimp myself to be sure I get everything I want in it. It's almost the only opensuse program I do that with. And yes, I did find that the exif data were there after saving to jpg; the problem must be with the pbase site. What confused me and made me think it was gimp was that it started immediately after compiling/installing gimp 2.4.7. Just an unlucky coincidence I suppose.
Jim
Plinnell
2008-06-09 17:44:42 UTC (over 16 years ago)
Message: 4
Date: Thu, 5 Jun 2008 07:25:23 -0400 From: Paka
Subject: Re: [Gimp-developer] EXIF data missing after jpg save To: gimp-developer@lists.XCF.Berkeley.EDU Message-ID:
Content-Type: text/plain; charset=us-ascii
I just checked the build logs for more recent Suse versions and ufraw does definitely have exif support.
Peter
Nils Philippsen
2008-07-07 09:53:57 UTC (over 16 years ago)
Just for the record (and I know I'm late), there is:
http://www.jpeg.org/jpeg/jpegls.html
Not that that's widely used ;-).
-- Bill _______________________________________________ Gimp-developer mailing list
