some error messages are hardcoded (not tranlate-able)
some error messages are hardcoded (not tranlate-able) Cristian Secar? 24 May 22:33
  some error messages are hardcoded (not tranlate-able) Sven Neumann 25 May 14:48
Cristian Secar?
2008-05-24 22:33:48 UTC (almost 17 years ago)
Perhaps a known issue ...
Example: in file history (detached tab), if I click on a file that is no longer available, two error message windows are opening here, one error message window that is related to this string
Opening '%s' failed:\n \n
%s
and another error message window that is related to this string
Could not open '%s' for reading: %s
On the first error window everything is ok. On the second error window the ending %s is not tranlate-able (in my example it says "No such file or directory"), because it is hardcoded in one of these two files, either libwmf-0-2-7.dll and/or libxml2.dll. Apparently these files holds other error messages too. The string "No such file or directory" is not present in any of my .po files.
Am I missing something ? All of the above are on Win32, GIMP 2.4.5.
Cristi
2008-05-25 14:48:25 UTC (almost 17 years ago)
Then you should file bug reports against these libraries and make sure that they provide translated error messages. That is not our business.
