"Created with GIMP" is a user defineable variable, a translatable string, or hardcoded ?
Cristian Secar?
2008-05-19 22:18:01 UTC (almost 17 years ago)
When going to File -> New... -> (a dialog window opens) -> click on + near Advanced options, there is an entry Comments: which is already filled with "Created with GIMP".
I seached for this string in all .po files but I didn't found it. I wanted to translate it. Is this string hardcoded ?
Cristi
2008-05-19 23:15:40 UTC (almost 17 years ago)
It's a string that the user can (and should) set. The initial default value is "Created with GIMP" and it is intentionally not marked for translation.
Cristian Secar?
2008-05-20 08:03:32 UTC (almost 17 years ago)
Ok, but this is a sting that the user can set globally if so desired (under program preferences), or each time a new file is created ?
I just want to know, not a real reason to change it, except perhaps the string's language in some circumstances.
Cristi
2008-05-20 09:11:01 UTC (almost 17 years ago)
The user can (and should) set this globally in the Preferences dialog. This value is then used for newly created images. For an existing image, the comment can be changed in the Image Properties dialog (Alt-Enter).
I wonder why you need to ask such questions on the gimp-developer list. Didn't you find the answer in the GIMP user manual?
