Option for locking tabs?
9 of 9 messages available
Option for locking tabs? ccrisis@gmail.com 18 May 03:43
  Option for locking tabs? Martin Nordholts 18 May 14:45
   Option for locking tabs? Jon Senior 18 May 20:41
  Option for locking tabs? Sven Neumann 18 May 15:08
   Option for locking tabs? ccrisis@gmail.com 19 May 01:15
    Option for locking tabs? Alastair M. Robinson 19 May 02:20
     Option for locking tabs? Alastair M. Robinson 19 May 02:29
    Option for locking tabs? Sven Neumann 19 May 20:32
     Option for locking tabs? Sven Neumann 20 May 08:58
ccrisis@gmail.com
2008-05-18 03:43:57 UTC (almost 17 years ago)
I was directed here for suggesting features. If this is the wrong place, I apologize.
When selecting tabs with a tablet, sometimes (often) there is accidental dragging and the tab ends up being pulled into it's own window. It's a big annoyance in my case, maybe other tablet users as well. I suggest an option to lock these.
D.R.
Martin Nordholts
2008-05-18 14:45:52 UTC (almost 17 years ago)
D.R.
Hello
It doesn't sound like a bad idea, but at the same time it feels like a hack and that the core problem is something else. If this was to be added though, it is necessary to sort out how to access this functionality in a discoverable way.
Regards, Martin Nordholts
2008-05-18 15:08:44 UTC (almost 17 years ago)
Have you tried to increase the gtk-dnd-drag-threshold? It's a GtkSetting that you can adjust in your ~/.gtkrc-2.0 file.
Jon Senior
2008-05-18 20:41:28 UTC (almost 17 years ago)
I suffer from the same problem from time to time. I'd love to see an option to "lock" the windows. I have a setup that works for me and that I don't change, and it'd be good to be able to lock that down. Not sure if that would need to be on the GTK side, or the GIMP side though.
ccrisis@gmail.com
2008-05-19 01:15:14 UTC (almost 17 years ago)
I did that now. While it does help a bit, I still think locking them would be ideal, at least to a user. I did some rough testing with a value of 100 and it happened anyways when working hurriedly across different tabs. I can't speak for others, but knowing they are locked would be preferable in my case.
2008-05-19 02:20:35 UTC (almost 17 years ago)
Hi :)
Yup, I find I accidentally move palettes out of the window too - so an option to lock a dock full of tabs would make my life easier. What I'd also like, since I'm in WishList mode, is to be able to lock a UI "State" - so that if a co-worker comes along, uses GIMP and then closes all my windows, not just the toolbox, they'll come back the way I like them next time I run GIMP. Currently, whenever that happens I have to spend a few minutes adding tabs to a new dock window.
All the best, --
2008-05-19 02:29:53 UTC (almost 17 years ago)
Hi again - replying to myself,,,
...so that if a co-worker comes along, uses GIMP and then closes all my windows, not just the toolbox, they'll come back the way I like them next time I run GIMP.
And I've just spotted how to do this - disable "Save window positions on exit", and click the "Save Window Positions Now" button - how I've failed to spot those for so long I don't know!
All the best, --
2008-05-19 20:32:34 UTC (almost 17 years ago)
I am about to add some code in SVN that allows you to lock individual tabs in their docks. Pretty similar to the "Lock To Panel" feature in the GNOME panel.
A preliminary patch with working UI but missing lock functionality is at http://sven.gimp.org/misc/gimp-dockable-lock.diff
2008-05-20 08:58:55 UTC (almost 17 years ago)
The full implementation is now in SVN trunk. Please test it if you can.
