functions in wacom
functions in wacom Dani Perez 13 May 19:07
  functions in wacom Chris Mohler 13 May 20:09
   functions in wacom Mike Williams 14 May 00:25
   functions in wacom Dani Perez 14 May 09:50
  functions in wacom Sven Neumann 15 May 09:58
Dani Perez
2008-05-13 19:07:40 UTC (almost 17 years ago)
functions in wacom
I need to get some features of the wacom like coordinates X and Y, pressure of pencil, etc in each instant of time. Does Gimp save this information in any file? Are there functions to obtain it?
Thanks in advance.
Chris Mohler
2008-05-13 20:09:09 UTC (almost 17 years ago)
functions in wacom
Have you looked at the wacdump program (linux - usually in a package called 'wacom-tools') or the utilities on the driver CD (windows)?
Chris
Mike Williams
2008-05-14 00:25:19 UTC (almost 17 years ago)
functions in wacom
not sure, highly unlikely
Yes.
Sorry for not being more helpful, don't have much time at the moment, but have a few tips on where you can get more help. You may find the wacom list helpful for questions like this:
https://lists.sourceforge.net/lists/listinfo/linuxwacom-discuss https://lists.sourceforge.net/lists/listinfo/linuxwacom-devel Another place to is the following where there are a couple of wacom related forums:
http://sourceforge.net/projects/linuxwacom/
Mike
Dani Perez
2008-05-14 09:50:55 UTC (almost 17 years ago)
functions in wacom
Yes, I have already looked wacdump and others but when I am drawing in Gimp, these don't work because Gimp get the X events for its own application (this doesn't happen with other apps like tgif). What I need is to obtain coordinates, pressure, etc of wacom while I am drawing in Gimp. I have been looking for function in gtk and in a plugin I could obtain this information but for obtaining it in Gimp maybe I should modify the Gimp code. Is there any easy way to do it or to get wacdump and Gimp working together ?
Thanks
Dani
2008-05-15 09:58:01 UTC (almost 17 years ago)
functions in wacom
This information is passed to the active tool in the GimpCoords struct. If you need to do anything with this information, then you probably need to write a tool.
