strange issues with gimp svn
strange issues with gimp svn The Peach 13 May 11:56
  strange issues with gimp svn Sven Neumann 14 May 09:16
   strange issues with gimp svn The Peach 15 May 11:20
    strange issues with gimp svn Sven Neumann 15 May 12:02
     strange issues with gimp svn The Peach 15 May 12:52
  strange issues with gimp svn The Peach 22 May 03:27
The Peach
2008-05-13 11:56:02 UTC (almost 17 years ago)
I've synched yesterday and I still get the same problems, I'll start reporting them here, because I'm not sure if I should open a bug report.
1 issue) If I use the color curves on a newly opened image, and modify all the curves (value, and rgb) when I press ok, I get a segfault.
2 issue) sometimes the opacity of the pencil tool (maybe even the brush, but I'm sticking on the pencil in this period, cause of some old school pix art) is set to 90% opacity, even if I've set it to 100%. I don't really know what is causing this, but this doesen't happen if I keep the tool options dialog open (!).
salut.
2008-05-14 09:16:17 UTC (almost 17 years ago)
Yes, that's a known problem. Still needs to be investigated.
The Peach
2008-05-15 11:20:44 UTC (almost 17 years ago)
thanks, I'm avoiding it by now.
About the second issue on the tool opacity, I'm digging what is causing this: it's really hard, usually I find it after few step, but too late already. Is there any keybinding introduced to restore the default values on the options of a tool?
PS: sorry Sven, but hitting the reply button I got you instead of the ML.
2008-05-15 12:02:38 UTC (almost 17 years ago)
It should be fixed since yesterday. At least it didn't show up for me since I fixed a memory corruption in the Curves code.
There's a Reset button at the bottom of the tool options dialog. If you absolutely need a key-binding, feel free to add one using the Keyboard Shortcut Editor.
The Peach
2008-05-15 12:52:02 UTC (almost 17 years ago)
I'm just asking because I'm not sure if this happens when I press without knowing it some keybinding
The Peach
2008-05-22 03:27:28 UTC (almost 17 years ago)
just understood what was happening: I just keep pressing the wrong keystroke, infact instead of pressing CTRL+Z for undoing (ps-menurc), I pressed CTRL+< which was "decrease current tool opacity" :D argh.
