A question on Gap -frame modify
5 of 7 messages available
mailman.5.1210186804.18107.... 07 Oct 20:26
  A question on Gap -frame modify Alchemie foto\\grafiche 08 May 17:36
   A question on Gap -frame modify Sven Neumann 08 May 17:59
mailman.5.1210273203.27269.... 07 Oct 20:26
  A question on Gap -frame modify Alchemie foto\\grafiche 11 May 10:23
   A question on Gap -frame modify Akkana Peck 11 May 18:28
    A question on Gap -frame modify gg@catking.net 11 May 19:22
2008-05-08 17:36:45 UTC (about 17 years ago)
With my surprise i noticed that in Gap -frame modify-apply filter on layers are available also some third party plugins as Mathmap
But then only the option "apply constant " is available not that i will need "apply variant"
The question is if there is any possible hack or workaround to activate the "apply variant" option for some 3d party plugin. (some if not all, but i don't want ask too much, just activate it for Mathmap or even for only a couple of mathmap codes will solve my problem)
If impossible now there is any plan to increase the compatibility in a close future?
PS i even try with others to solve in the other way around adding animation option to that MM codes, but that fails ,no one of the tenctative was fully sucessful
Alchemie Foto\grafiche
Scopri il Blog di Yahoo! Mail: trucchi, novità, consigli... e la tua opinione!
2008-05-08 17:59:45 UTC (about 17 years ago)
Sure. Read docs/howto/txt/HOWTO-write-animated-plug-ins.txt in the GAP source code.
2008-05-11 10:23:54 UTC (about 17 years ago)
source code.
thank i read it and was a pleasant surprise, the process seems less complex of what i feared and is described step by step
But at the very beginning, here
" 1.a # for bourne and ksh users:
GAP_DEBUG=y
export GAP_DEBUG
1.b # for csh users
setenv GAP_DEBUG y "
Now i don't know if i am a bourne, a ksh, or a csh user, i just know (and not as expert) how to use the terminal of my distro Ubuntu Hardy Heron.
So is that default terminal adapt for this use (if not what else?) and if adapt is "a" , "b", or something else the command i have to use for start ?
i fear that will not work with MathMap ( is only apparently able to memorize the last setting used but if called with the "repeat" option just run with the default values not with last used) but i will like try with "liquid resize" that is another plugin i wish to use in animation
Akkana Peck
2008-05-11 18:28:00 UTC (about 17 years ago)
Alchemie fotografiche writes:
GAP_DEBUG=y
export GAP_DEBUG
1.b # for csh users
If you're a Linux user and you don't know (haven't changed it explicitly), then you're a bash user, which uses the same syntax as Bourne shell.
So use 1.a.
...Akkana
gg@catking.net
2008-05-11 19:22:01 UTC (about 17 years ago)
GAP_DEBUG=y export GAP_DEBUG
1.b # for csh users setenv GAP_DEBUG y "
So use 1.a.
...Akkana
One thing is fur sure with linux is there's not ONE answer.
echo $SHELL
should give the console login shell XTERM_SHELL may be different.
Linux has more shells than a desert island beach. Each distro has it's own prefs.
