Edit->Copy bug/misbehaviour
Edit->Copy bug/misbehaviour David Gowers 04 May 14:57
David Gowers
2008-05-04 14:57:48 UTC (almost 17 years ago)
I'm not yet sure I should file this as a bug, since I find myself confused about it.
You may need 2.5 or SVN to reproduce this?
Do the following in order to reproduce it: 1. Open an image
2. Make sure that nothing is selected, by using 'Select->None' 3. Edit->Copy
4. Notice how the Clipboard Brush goes blank, rather than changing to the copied data or a cropping of the copied data (since 512x512 is the limit of clipboard brush)
5. Check that the image data copied okay, with Edit->Paste as->New image 6. Go back to the first image
7. Select->All
8. Edit->Copy
9. Notice that now the clipboard brush correctly contains the copied pixel data.
It is my understanding that usually, having nothing selected is treated the same as having everything selected. I guess that this behaviour is probably a bug, and likely just a simple mistake, readily fixed (I don't have easy access to a SVN checkout currently, So I cannot verify this) If not, I hope someone will inform me so that I can file a bug :)
-- David
