Running Gimp 2.4.x and 2.5.0 side by side
8 of 8 messages available
Running Gimp 2.4.x and 2.5.0 side by side Jon Senior 27 Apr 22:30
  Running Gimp 2.4.x and 2.5.0 side by side xsdg 28 Apr 02:01
   Running Gimp 2.4.x and 2.5.0 side by side Jon Senior 28 Apr 10:04
   Running Gimp 2.4.x and 2.5.0 side by side Jon Senior 28 Apr 16:26
    Running Gimp 2.4.x and 2.5.0 side by side Alexandre Prokoudine 28 Apr 19:01
     Running Gimp 2.4.x and 2.5.0 side by side Jon Senior 28 Apr 19:18
      Running Gimp 2.4.x and 2.5.0 side by side Alexandre Prokoudine 28 Apr 19:25
     Running Gimp 2.4.x and 2.5.0 side by side Sven Neumann 28 Apr 20:18
Jon Senior
2008-04-27 22:30:24 UTC (almost 17 years ago)
Sorry if this is the wrong list for this question, but I figure the developers are most likely to be doing this.
I've followed the instructions on the site. BABL, GEGL and Gimp are all installed to /usr/local/gimp2.5. I've installed a modified version of the suggested wrapper script (with the correct paths) in /usr/local/bin.
Any attempt to run gimp-2.5 results in the message
------ Libgimp version mismatch!
The GIMP binary cannot run with a libgimp version other than its own. This is GIMP 2.5.0, but the libgimp version is 2.4.5.
Maybe you have GIMP versions in both /usr and /usr/local ? ------
I've tried carrying out the functions of the wrapper by hand. I've run ldconfig -N on the .../gimp-2.5/lib directory.
I'm using stow to manage the system so I could theoretically just use it to swap the versions in and out, but I'd rather be able to run them properly side-by-side.
Any suggestions?
xsdg
2008-04-28 02:01:45 UTC (almost 17 years ago)
Did you make sure to `export LD_LIBRARY_PATH`? (I'm not sure what the equivalent might be for different shells). This is likely the problem if you see a difference between the output of `ldd /path/to/gimp2.5/bin/gimp`
and
`ldd --library-path /path/to/gimp2.5/lib /path/to/gimp2.5/bin/gimp`
Note that you can check for sure if this might be the problem by running gimp2.5 directly with the overridden library path `/lib/ld-2.7.so --library-path /path/to/gimp2.5/lib /path/to/gimp2.5/bin/gimp`
cheers, --xsdg
Jon Senior
2008-04-28 10:04:31 UTC (almost 17 years ago)
Yup. The wrapper script does that, but I've tried doing it by hand as well.
and
ldd reports it linking to /usr/local/lib, so confirming that it's missing the target! My version of glibc is 2.3.6 according to ldconfig --version and my version of ldd doesn't have the --library-path option.
I tried that and it still produced the same error. There's something going on in the linking stage of gimp I think. I'll try building static libraries only and see if that does it.
Jon Senior
2008-04-28 16:26:03 UTC (almost 17 years ago)
Well. I compiled it with --enable-shared=no --enable-static=yes, and it works fine. It seems slightly faster on some operations (Although I could easily be imagining that), but sadly still doesn't resolve my issue of the CMYK values in the colour sampler being calculated differently from Photoshop, making it hard to follow Lee Varis' advice on obtaining good skin tones.
Thanks for your help. Looking forward to the final release, and I'll continue to play with 2.5 for testing purposes.
2008-04-28 19:01:13 UTC (almost 17 years ago)
Color management isn't fully implemented yet (previews will give you wrong colors in plug-ins if you use AdobeRGB as working space profile, too). No idea when this will be fixed.
Alexandre
Jon Senior
2008-04-28 19:18:12 UTC (almost 17 years ago)
To be honest, aside from the usual desire for adjustment layers (or something similar), my only real wish at the minute would be that the CMYK values that are generated in the Sample Points window matched those of PS. Or that I could choose the rendering algorithm. Is this something that will appear naturally as a part of the colour management, or is it a separate issue (C is not my forte, or I'd dive in and find out for myself!)?
2008-04-28 19:25:40 UTC (almost 17 years ago)
> Color management isn't fully implemented yet (previews will give you > wrong colors in plug-ins if you use AdobeRGB as working space profile, > too). No idea when this will be fixed.
This is probably something that should be discussed in a separate thread.
Making all related widgets color managed is the plan. If you are willing to spend some time on doing this, I'm sure you help will be very much appreciated. I also can't comment on technical side, but someone like Sven who did most of work on initial CMM support can :)
Alexandre
2008-04-28 20:18:29 UTC (almost 17 years ago)
The preview of plug-ins has absolutely nothing to do with the RGB -> CMYK conversion of the Color Picker tool. Why are you mentioning this here?
