script-fu menu
13 of 13 messages available
script-fu menu Luis A. Florit 01 Mar 23:47
  script-fu menu Laxminarayan Kamath 02 Mar 10:55
   script-fu menu Luis A. Florit 02 Mar 13:44
    script-fu menu Bill Skaggs 02 Mar 17:06
    script-fu menu Joao S. O. Bueno 02 Mar 19:22
    script-fu menu Kevin Cozens 02 Mar 19:42
  script-fu menu Kevin Cozens 02 Mar 19:34
   script-fu menu Sven Neumann 04 Mar 20:24
    script-fu menu Kevin Cozens 04 Mar 23:16
     script-fu menu Sven Neumann 05 Mar 08:53
      script-fu menu Kevin Cozens 08 Mar 20:29
       script-fu menu Sven Neumann 10 Mar 20:14
        script-fu menu Martin Nordholts 11 Mar 07:54
Luis A. Florit
2008-03-01 23:47:55 UTC (about 17 years ago)
script-fu menu
I am writting a (almost finished) plugin in script-fu and wanted some features for the script-fu main option window of my plugin, but I was unable to find this googling. So it's probably not possible...
I want to do these on the plugin option window:
1) Gray-out some options according to checkboxes; 2) Add arbitrary text, horizontal lines, boxes, or something like that.
I would appreciate any pointer where I can find the above, if they are available features.
Thanks a lot,
L.
Laxminarayan Kamath
2008-03-02 10:55:27 UTC (about 17 years ago)
script-fu menu
I am not a GIMP developer, though I have been a spectator on this list for a while now.
I suggest that you specify exactly what you are trying, and what exactly you are looking for.
A detailed work-flow and a UI mock-up image would best describe what you want.
Specify the problem.. not the solution. I HTH .
Luis A. Florit
2008-03-02 13:44:12 UTC (about 17 years ago)
script-fu menu
* El 02/03/08 a las 15:25, Laxminarayan Kamath chamullaba:
Sorry, I thought I was clear enough (did I specify the solution??) What I want to do is what is pretty standard in these cases:
My script-fu has a lot of options, and a check box to use default values of these options. I want these options to become grayed out when the check box is checked. Just that.
My other question was if it is possible to add text to a script-fu option window that is not related to an option of the script.
But I do not know if these are possible in script-fu, and I didn't find a complete enough reference for script-fu.
Thanks again,
L.
Bill Skaggs
2008-03-02 17:06:26 UTC (about 17 years ago)
script-fu menu
You were certainly clear enough, but there is no way to do that using script-fu. If you need fine control of the interface, you'll have to use a more powerful language.
-- Bill
Joao S. O. Bueno
2008-03-02 19:22:17 UTC (about 17 years ago)
script-fu menu
Thanks again,
L.
Hi there,
At first, I have to? say to you it is likely these chanegs are not going to be made.
The auto-interface build up in script-fu, perl-fu and python-fu is a convenience, and presented "as is". More sofisticated plug-ins should use GTK+ to draw their own interfaces . Unfortunatelly this is no option when you are using Scheme (script-fu).
If you do your work in python, however, you have, in the opinos of many people, and in my strong opinion, an easier to work langauge than Scheme, and will gain the flexibility to build your custom interface as you please. (And still, won't miss any flexibilit otherwise avaliable only to plug-ins written in C). Ah, there are also Ruby bindings, should you prefer Ruby than Python.
And finally, so that you don't think you are alone in this desire for greater control on the authomatic interfaces, I have thoguth about that as well, and it is possible that something more or less like what you are asking to be implemented for Python plug-ins.
js ->
Kevin Cozens
2008-03-02 19:34:44 UTC (about 17 years ago)
script-fu menu
You can't do either of the above in Script-Fu. Adding new parameter types to allow adding extra text or horizontal lines is possible but is not currently on the ToDo list. Greying out other items based on selections being made is a feature that is unlikely to be seen in Script-Fu anytime in the near, or distant, future.
Kevin Cozens
2008-03-02 19:42:50 UTC (about 17 years ago)
script-fu menu
There is some documentation about Script-Fu at http://www.gimp.org/docs/. I have been putting together my own set of documentation for Script-Fu which you can find at: http://www.ve3syb.ca/wiki/doku.php?id=software:sf:start
Amongst the things you will find there are a list of the items you can use in the register block.
2008-03-04 20:24:41 UTC (about 17 years ago)
script-fu menu
What about the possibility to add an example image as proposed in bug #520066 ?
Kevin Cozens
2008-03-04 23:16:13 UTC (about 17 years ago)
script-fu menu
It would be a useful feature. Again, it isn't on my ToDo list for Script-Fu. This feature would be of enough general use that it should be available to all scripting systems.
It would need to be decided how to implement the feature. How would one tell GIMP that a preview for a script is available (and what the file name is called)? Where would the preview images be stored?
2008-03-05 08:53:06 UTC (about 17 years ago)
script-fu menu
I don't see this as a feature that the GIMP core would implement. It is up to the scripting language(s) to do that.
Just add a function like script-fu-example-image-register that associates an image filename with the procedure. The images could live in the scripts folder, right next to the script.
Kevin Cozens
2008-03-08 20:29:42 UTC (about 17 years ago)
script-fu menu
I don't know if you would consider a library as being part of the GIMP core. This feature could be implemented in a new GIMP library or as part of libgimpui.
An existing GSoC 2008 project idea is to provide a unified UI for scripting. If a unified UI is considered a desirable feature, why would you say that each language binding should provide its own method of registering/providing preview images?
The one question I forgot to ask is how would a person get to see these preview images? Using an image preview browser? A "show preview" button (or menu item) in the scripts UI window? Some other mechanism (yet to be decided)?
2008-03-10 20:14:15 UTC (about 17 years ago)
script-fu menu
How so? This is really something that can be implemented in about ten lines of code. Most of this code will be Script-Fu specific. So I don't see how this could be part of any GIMP library.
That is indeed the more difficult question here. Besides the question whether such static example images would be useful at all. The easiest solution is probably to put it inside the scripts UI window similar to how plug-ins place their previews.
Martin Nordholts
2008-03-11 07:54:27 UTC (about 17 years ago)
script-fu menu
As far as I understand the point is to allow users to get an overview of what effect the different filters will have on the image so then putting this static preview in the scripts UI window where the dynamic previews are doesn't make any sense. Or did I misunderstand you?
- Martin
