improving the Print plug-in
improving the Print plug-in Sven Neumann 29 Jan 09:20
improving the Print plug-in Sven Neumann 30 Jan 23:18
2008-01-29 09:20:32 UTC (about 17 years ago)
we have a serious problem with the Print plug-in on the Windows platform. See http://bugzilla.gnome.org/show_bug.cgi?id=480086 As it seems this is unlikely to ever get fixed in GTK+, so we should consider to do something about it in our code, at least for GIMP 2.6.
The way that GTK+ Print is designed an application should provide two or even three Print-related menu entries:
Page Setup Print Preview
Print
The Print Preview menu entry is optional as this functionality can also be accessed from the Print dialog. Currently the Print plug-in also provides a single menu entry "Print". The "Page Setup" functionality is folded into the plug-in dialog. And this is what breaks on Windows. It is probably also confusing for the users as they may be looking for the "Page Setup" in the menus since they know this from other applications.
How can be solve this? Does it make sense to add "Page Setup" to the Image->File menu? Won't this be too confusing as we also have Image->Image->Print Size?
2008-01-30 23:18:44 UTC (about 17 years ago)
OK then, I have opened bug 513291 for this.
BTW, Bill, could you perhaps check if there's a way to configure your mail client to include an In-Reply-To field in the message headers? It would be so much nicer if your replies would appear in the thread you are answering to. Thank you...
