[SVN 24537], SIGSEGV in Colors -> Curves
[SVN 24537], SIGSEGV in Colors -> Curves Jean-Luc Coulon (f5ibh) 05 Jan 12:16
  [SVN 24537], SIGSEGV in Colors -> Curves Kevin Cozens 05 Jan 18:03
[SVN 24537], SIGSEGV in Colors -> Curves Jean-Luc Coulon (f5ibh) 06 Jan 13:05
2008-01-05 12:16:55 UTC (over 17 years ago)
- I've loaded a tif file (43M) - called Colors -> Curves
- got a SIGSEGV
Attached the gdb session
BTW : the same operation on the same file works with 2.4.3
Regards (and happy 2008)
Jean-Luc
[New Thread 0x40800950 (LWP 12067)] [New Thread 0x41001950 (LWP 12068)]
[New Thread 0x41802950 (LWP 12069)]
[New Thread 0x42003950 (LWP 12070)]
Removing duplicate PDB procedure 'file-psd-load' registered by '/opt/gimp-2.5.0/lib/gimp/2.0/plug-ins/psd-load' [New Thread 0x42804950 (LWP 12083)]
[New Thread 0x43005950 (LWP 12084)]
[Thread 0x43005950 (LWP 12084) exited] [Thread 0x42804950 (LWP 12083) exited] [New Thread 0x42804950 (LWP 12086)]
[New Thread 0x43005950 (LWP 12087)]
[New Thread 0x43806950 (LWP 12088)]
[New Thread 0x44007950 (LWP 12089)]
[New Thread 0x44808950 (LWP 12090)]
[New Thread 0x45009950 (LWP 12091)]
[Thread 0x45009950 (LWP 12091) exited] [Thread 0x43806950 (LWP 12088) exited] [Thread 0x44808950 (LWP 12090) exited] [Thread 0x44007950 (LWP 12089) exited] [Thread 0x43005950 (LWP 12087) exited] [Thread 0x42804950 (LWP 12086) exited]
Program received signal SIGSEGV, Segmentation fault. [Switching to Thread 0x2aaef13357e0 (LWP 12062)] 0x0000000000000000 in ?? ()
(gdb) bt
#0 0x0000000000000000 in ?? ()
#1 0x00000000004dfe1e in gimp_image_map_tool_create_map (tool=0xaa4b10) at gimpimagemaptool.c:448
#2 0x00000000004dff6b in gimp_image_map_tool_initialize ( tool=, display=0x1f43580, error=) at gimpimagemaptool.c:337
#3 0x00000000004d5226 in gimp_curves_tool_initialize (tool=0xaa4b10, display=0x1f43580, error=0x7fffbff16538) at gimpcurvestool.c:241 #4 0x0000000000502e56 in gimp_tool_initialize (tool=0xaa4b10, display=0x1f43580) at gimptool.c:427 #5 0x00000000004c97d4 in tool_manager_initialize_active ( gimp=, display=0x1f43580) at tool_manager.c:236 #6 0x00002aaeee555a1f in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0 #7 0x00002aaeee5696e8 in ?? () from /usr/lib/libgobject-2.0.so.0 #8 0x00002aaeee56b145 in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0 #9 0x00002aaeee56b533 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0 #10 0x00002aaeee555a1f in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0 #11 0x00002aaeee5693be in ?? () from /usr/lib/libgobject-2.0.so.0 #12 0x00002aaeee56b145 in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0 #13 0x00002aaeee56b533 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0 #14 0x00002aaeebdada73 in ?? () from /usr/lib/libgtk-x11-2.0.so.0 #15 0x00002aaeee555a1f in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0 #16 0x00002aaeee5696e8 in ?? () from /usr/lib/libgobject-2.0.so.0 #17 0x00002aaeee56b145 in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0 #18 0x00002aaeee56b533 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0 #19 0x00002aaeebf92f88 in gtk_widget_activate () from /usr/lib/libgtk-x11-2.0.so.0 #20 0x00002aaeebe94166 in gtk_menu_shell_activate_item () from /usr/lib/libgtk-x11-2.0.so.0 #21 0x00002aaeebe95b26 in ?? () from /usr/lib/libgtk-x11-2.0.so.0 #22 0x00002aaeebe87d9f in ?? () from /usr/lib/libgtk-x11-2.0.so.0 #23 0x00002aaeee555a1f in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0 #24 0x00002aaeee569ac8 in ?? () from /usr/lib/libgobject-2.0.so.0 #25 0x00002aaeee56ae6f in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0 #26 0x00002aaeee56b533 in g_signal_emit () from /usr/lib/libgobject-2.0.so.0 #27 0x00002aaeebf8ec05 in ?? () from /usr/lib/libgtk-x11-2.0.so.0 #28 0x00002aaeebe810b2 in gtk_propagate_event () from /usr/lib/libgtk-x11-2.0.so.0 #29 0x00002aaeebe82055 in gtk_main_do_event () from /usr/lib/libgtk-x11-2.0.so.0 #30 0x00002aaeec33e22c in ?? () from /usr/lib/libgdk-x11-2.0.so.0 #31 0x00002aaeef061e24 in g_main_context_dispatch () ---Type to continue, or q to quit--- from /usr/lib/libglib-2.0.so.0
#32 0x00002aaeef06510d in ?? () from /usr/lib/libglib-2.0.so.0 #33 0x00002aaeef065407 in g_main_loop_run () from /usr/lib/libglib-2.0.so.0 #34 0x000000000046a857 in app_run (full_prog_name=, filenames=0x0, alternate_system_gimprc=0x0, alternate_gimprc=0x0, session_name=, batch_interpreter=0x0, batch_commands=0x0, as_new=0, no_interface=0, no_data=0, no_fonts=0, no_splash=0, be_verbose=0, use_shm=1, use_cpu_accel=1, console_messages=0, use_debug_handler=0, stack_trace_mode=GIMP_STACK_TRACE_QUERY, pdb_compat_mode=GIMP_PDB_COMPAT_WARN) at app.c:252 #35 0x000000000046b7be in main (argc=1, argv=0x7fffbff18498) at main.c:387 (gdb)
Kevin Cozens
2008-01-05 18:03:37 UTC (over 17 years ago)
Jean-Luc Coulon (f5ibh) wrote:
- I've loaded a tif file (43M) - called Colors -> Curves - got a SIGSEGV
From the gdb session messages:
In late December there was an update to the PSD file loader. The old loader was called psd-load. The new PSD loader is called psd. The message above indicates you still have the old PSD file loader installed. Remove the psd-load file referenced in the above message.
2008-01-06 13:05:38 UTC (over 17 years ago)
Hi Bill,
Le 05.01.2008 17:04:35, William Skaggs a écrit :
From: Jean-Luc Coulon (f5ibh) jean.luc.coulon@gmail.com
- called Colors - Curves
- got a SIGSEGV
You can expect some instability for a while, because of the introduction of gegl into the tools. It probably isn't useful to file bug reports or send messages to this list until things have stabilized a bit -- or if you have a problem that persists for longer than a week. A mention on #gimp would certainly be appropriate, though.
Ok, thanks, I will wait…
Best wishes,
-- Bill
Jean-Luc
