Compiling "denoise" plug-in
Compiling "denoise" plug-in Jim Sabatke 22 Dec 16:47
  Compiling "denoise" plug-in Tor Lillqvist 24 Dec 23:03
Jim Sabatke
2007-12-22 16:47:53 UTC (about 17 years ago)
I downloaded and tried to compile Roland Simmen's "DeNoise" plug-in. It only comes with source files, no Makefile, no configure to make the Makefile. gimptool-2.0 doesn't seem to like multiple *.c source files.
Would someone please point me in the right direction to get this plug-in compiled and working?
TIA,
Jim
Tor Lillqvist
2007-12-24 23:03:56 UTC (about 17 years ago)
Well, I don't know anything about DeNoise in particular, but have you tried then just running gimptool-2.0 --dry-run with some dummy.c filename to see the correct flags to use, then copy-paste the output of that, i.e. the command to use to compile a plug-in with just one source file dummy.c, replaceing dummy,c with the actual source files of DeNoise?
--tml
