gimp permanent data AND parasiterc
gimp permanent data AND parasiterc Lionel Tarazon Alcocer 11 Dec 18:18
  gimp permanent data AND parasiterc Sven Neumann 11 Dec 18:23
2007-12-11 18:18:28 UTC (over 17 years ago)
I need to store, let's say, my plug-in configuration:
(1) ¿Is there any way to store data (similarly to gimp_set_data, for example) so that gimp loads it automatically at start? I don't mean using parasites stored in an XCF file.
If not, ¿Should I use for this purpose any of the rc files in "$HOME/.gimp-2.4" to store this data, or It's just better to create my own file instead?
(2) ¿What's the parasiterc file used for?
Thanks in advance.
2007-12-11 18:23:29 UTC (over 17 years ago)
On Tue, 2007-12-11 at 18:18 +0100, Lionel Tarazon Alcocer wrote:
(1)
You can set a persistent global parasite using gimp_parasite_attach().
That's an alternative way of doing it. Do whatever you prefer. If you want to create your own file, please make sure that it is named after your plug-in. And consider to use GKeyFile for writing and loading it.
(2)
It is used to store persistent global parasites.
