improving QMask mode
7 of 7 messages available
improving QMask mode David Gowers 30 Nov 13:15
  improving QMask mode Liam R E Quin 30 Nov 20:45
   improving QMask mode David Gowers 01 Dec 08:35
    improving QMask mode Sven Neumann 01 Dec 12:07
     improving QMask mode David Gowers 01 Dec 14:50
     improving QMask mode Chris Mohler 02 Dec 01:03
  improving QMask mode Chris Mohler 01 Dec 01:02
David Gowers
2007-11-30 13:15:33 UTC (over 17 years ago)
I believe that QMask mode could be made quicker to use, by providing an option to:
a) Reset the FG/BG colors to black and white upon entering qmask mode and
b) Push the context before entering qmask mode, and pop it when exiting qmask mode.
With the sum effect that you needn't destroy the colors that you were using in order to paint on the QMask (I myself always find myself resetting the colors to default before I draw on the QMask), and you start out with the two most useful 'colors' set as FG+BG.
What do you think of this? If I get the go ahead I'll implement this.
Liam R E Quin
2007-11-30 20:45:36 UTC (over 17 years ago)
Interesting idea. I admit I hardly ever use quickmask because most of the images I work with are grayscale, and if you paint with a soft brush in the gray quickmask you can't tell where you selection starts. So I have to switch to RGB mode first right now.
This makes me wonder if there should be separate sets of colours stored for different painting modes, rather than a push/pop model.
If I change the colour in quickmask mode, e.g. to 50% gray, next time I use quickmask it could go back to that.
Liam
Chris Mohler
2007-12-01 01:02:24 UTC (over 17 years ago)
I like "a" - I switch to black and white in QMask very often. Not sure exactly what you mean by "b", so no opinion...
Chris
David Gowers
2007-12-01 08:35:37 UTC (over 17 years ago)
Hi Liam,
For Chris's benefit : it means that the context that was being used is stored, and restored after qmask. so the FG and BG that you were previously using return.
That depends on what mask color you set. Set black or white instead of the default red, does that help?
For QMask (which is an editing mode), certainly. For 'paint modes' (eg multiply, screen, dissolve), it would be fast; I suspect it would also be confusing for novices. I would definitely like it as an option, because I almost never want the same colors for drawing in Multiply mode or Grain Merge mode as I do for drawing in Normal mode.
Let's review the paint modes: 1. Normal, Dissolve, Behind, Color erase. 2. Overlay, Soft light, Hard Light, Grain Merge, Grain Extract 3. Multiply, Divide, Screen
4. Difference, Addition, Subtract, Dodge, Burn 5. Darken, Lighten, Hue, Saturation, Color, Value
Each number represents a group of paint modes, in which a given color has more or less the same meaning.
1. Direct color change.
2. Linear color change
3. Cumulative color change
4. Linear one-way color change
5. Direct partial color change (effects only some components)
Surely some people disagree with me here. I expect that, as GEGL approaches, this sort of control will become more important. Now, I'm talking about sharing color settings between each group of paint modes; Later, it will become sharing (X) settings between different Ops (since gegl will greatly diversify the available ways to paint, a static mode list becomes infeasible). Therefore I believe that a facility that allows the user to group modes which will share contexts is the way to go for future compatible handling of this issue.
This is a good idea! Does anyone know how to do it non-hackishly? Is new support code needed?
Liam
Liam Quin - http://www.holoweb.net/~liam/ XML Activity Lead, W3C, http://www.w3.org/People/Quin/ Pictures from old books: http://fromoldbooks.org/ Ankh: irc.sorcery.net irc.gnome.org www.advogato.org
2007-12-01 12:07:55 UTC (over 17 years ago)
It would mean a lot more than that. Also any changes to the current brush, pattern, gradient, paint-mode, ... would be undone when the context is popped.
We currently use this to allow scripts to work in their own context. I am not sure if it is a good idea to use the context push/pop mechanism in the user interface.
David Gowers
2007-12-01 14:50:41 UTC (over 17 years ago)
Hi Sven,
I thought that you could mask it so that only FG and BG were effected.
Chris Mohler
2007-12-02 01:03:51 UTC (over 17 years ago)
@David: Thanks for explaining.
A power user might benefit from having a QMask option in preferences for "keep separate context for QMask". I can think of a couple of scenarios where using separate settings in QMask could prove useful.
Chris
