Still need a home for my plug-ins
Still need a home for my plug-ins Jim Sabatke 30 Nov 04:05
  Still need a home for my plug-ins Kevin Cozens 30 Nov 06:02
   Still need a home for my plug-ins Jim Sabatke 01 Dec 00:22
Jim Sabatke
2007-11-30 04:05:25 UTC (over 17 years ago)
This is a second posting. I think I sent the first from a different address than the one I signed up with. Apologies if this shows up twice.
My free time on the file hosting site I've been using is almost up. I had several suggestions before that I should upload the files to the plug-in registry site. I may be missing something, but it looks like I need some sort of special privileges to do that.
Any help would be welcome.
TIA
Jim
Kevin Cozens
2007-11-30 06:02:45 UTC (over 17 years ago)
Look at the right hand side of the page under "Coders Corner". It has a link for you to register as a plug-in author. The link below that let's you change plug-in information once you have registered.
Jim Sabatke
2007-12-01 00:22:23 UTC (over 17 years ago)
I *finally* got past the login prompt to get to the file upload area. Thanks for your help. Apologies for the *noise* of the extra entries in the latest modification area. Hopefully their will be more added and the extras will fall off the screen.
Jim
