Script-fu gimp 2.4.1 causes seg fault on linux but not on win
| Script-fu gimp 2.4.1 causes seg fault on linux but not on win | david | 18 Nov 23:01 |
Dear gimp-developers,
the following Script-fu written to test some of the new features of
the TinyScheme version of Script-fu seems to work perfectly on Windows
2000 pro (Gimp 2.4.1) but fails on Ubuntu 7.10 standard amd64 and on
Ubuntu 7.10 i386.
It runs for a variable time and fails on different directories/files
sometimes up to 300,000 files into a run. I am happy to directly help
you as much as I can and will furnish any data that you may need.
regards David Martin
;;; originated by Jim Blandy --- July 1998
;;; modified by David M. W. Martin to work with Gimp 2.4 Script-fu
18/11/07
;;; works on win2000 32bit gimp 2.4.1 as far as I can see faultlessly
;;; causes segmentation fault on ubuntu 7.10 amd64 and i386 after
variable
;;; numbers of files sometimes 250,000 into run at similar places,
;;; nothing strange about files it fails on, usually on changing to a
new dir.
;;; /usr/lib/gimp/2.0/plug-ins/script-fu: fatal error: Segmentation
fault
;;; gimp still runs but "Refresh Scripts" is missing and all Script-fu
entries
;;; gimp must be restarted!
(define (test-for-each-file outputdevice dirname regex)
(let* ((count 0) ;initialise count
(seconds (car(gettimeofday)))) ;initialise time of day in
seconds
(case outputdevice
((0) (gimp-message-set-handler ERROR-CONSOLE))
((1) (gimp-message-set-handler CONSOLE))
((2) (gimp-message-set-handler MESSAGE-BOX)))
(define (for-each-file perform-func-on root)
(let visit ((root root));reset root
(let ((should-recurse (perform-func-on root)))
(if (and should-recurse (if (= (file-type root) FILE-TYPE-DIR)#t
#f));dir?
(let ((dir (dir-open-stream root)))
(let loop ()
(let ((entry (dir-read-entry dir)))
(cond
((eof-object? entry) #f) ;if eof signal false and drop
through
(( or (string=? entry ".") ;current directory or
(string=? entry "..")) ;parent directory
(loop));recurse loop
(else(visit (string-append root DIR-SEPARATOR
entry)) ;recurse visit
(loop)) ;recurse loop
) ;end cond
) ;end let dir-read-entry
) ;end let loop
) ;end let dir-open-stream
) ;end if a dir
) ;end let should-recurse
) ;end of let visit
) ;end of for-each-file function
(define (perform-func-on file)
(set! count (+ count 1)) ;count files visited
(if (re-match regex file) ;check regex
(gimp-message (string-append "found "file " number "(number->string
count)))
) ;end if
(gimp-message (string-append file " number "(number->string count)))
) ;end perform-func-on
(for-each-file perform-func-on dirname);main routine called from here
(gimp-message (string-append "elapsed seconds "
(number->string (- (car(gettimeofday)) seconds))" count "
(number->string count))) ; print elapsed time and number
of files
) ;end test-for-each-file let*
(script-fu-register
"test-for-each-file"
_"_test-for-each-file..."
"Chose output media, select directory to recurse from,
optional regular expression to be applied to each filename "
"David(dot)Martin(at)sixtyfive(dot)plus(dot)com"
"David Martin, 2007. Public Domain GPL."
"18/11/07 "
SF-OPTION _"Message output device" '("ERROR-CONSOLE" "CONSOLE"
"MESSAGE-BOX" )
SF-DIRNAME _"Directory" "/home/david/test_images"
SF-STRING "File or Directory contains (regex)" ".jpg$"
(script-fu-menu-register "test-for-each-file" "/Xtns/")
