Problems using some API functions
Problems using some API functions Dani Perez 09 Nov 13:13
  Problems using some API functions Sven Neumann 09 Nov 13:39
Dani Perez
2007-11-09 13:13:26 UTC (over 17 years ago)
I am trying to use some functions of the application API, for example:
gimp_text_layer_new gimp_image_get_by_ID
I have included in my plug-in code the following two header files: #include
#include
But I am still getting a compilation error saying unreference functions.
Am I missing a header file that I should include? any idea about the cause of the problem?
Thanks in advance.
Dani
2007-11-09 13:39:05 UTC (over 17 years ago)
You can't use the application API from your plug-in. This is the internal API that is used in the GIMP core.
