Enhancement - Diagonal line crop guide
7 of 7 messages available
Enhancement - Diagonal line crop guide Tim Jedlicka 07 Nov 05:03
  Enhancement - Diagonal line crop guide Martin Nordholts 07 Nov 17:14
   Enhancement - Diagonal line crop guide Martin Nordholts 07 Nov 17:30
  Enhancement - Diagonal line crop guide Sven Neumann 12 Nov 21:29
   Enhancement - Diagonal line crop guide Liam R E Quin 04 Feb 23:13
Enhancement - Diagonal line crop guide Tim Jedlicka 11 Nov 09:10
  Enhancement - Diagonal line crop guide Martin Nordholts 11 Nov 10:00
Tim Jedlicka
2007-11-07 05:03:41 UTC (over 17 years ago)
(repost - got lost somewhere the first time)
I stumbled upon this link describing the use of the Diagonal (45 degree diagonal from each corner of an image) as the optimum crop guide ("better" than rule-of-thirds or golden rule).
http://www.diagonaalmethode.nl/
I hacked together a patch to add the Diagonal crop guide. So, should I open an enhancement bugzilla and include the patch? My patch isn't perfect - hence posting here since it requires some discussion. If the crop box is a portrait, then it works, if landscape (X > Y) then the guides extend beyond the crop rectangle. I don't know how to fix this cleanly (using an if statement doesn't seem efficient).
Any guidance (on or off list) would be appreciated. Thanks...Tim
Martin Nordholts
2007-11-07 17:14:34 UTC (over 17 years ago)
Hi Tim, we appreciate your efforts.
This should be solvable without caring about if the rectangle is in portrait or landscape. For each line to draw, you have
1. one starting point (a corner, e.g. upper left) 2. one direction (e.g. 45 degrees down to the right for the upper left corner)
3. another line (e.g. the bottom horizontal line for the upper left corner)
Now you need to calculate the end point by calculating where the 45 degree line intersects with other line. Then draw a line between the start point and the calculated intersection point.
Martin Nordholts
Martin Nordholts
2007-11-07 17:30:35 UTC (over 17 years ago)
Martin Nordholts
Oops, it of course depends on portrait or landscape which line you hit first. I think you will have to throw in an if there.
- Martin Nordholts
Tim Jedlicka
2007-11-11 09:10:32 UTC (over 17 years ago)
* Tim Jedlicka wrote:**
*>>* I stumbled upon this link describing the use of the Diagonal (45 degree *>>* diagonal from each corner of an image) as the optimum crop guide ("better" *>>* than rule-of-thirds or golden rule). ...
I figured out a way to avoid the "if" statement. However, I don't know which method would be more efficient. i.e. should I try to avoid the "if"? These diagonal crop guides are very dynamic as you change your crop rectangle so I don't want to bog down the rendering. Just need some guidance on which route to take. I'll then have some follow up questions since I am not much of a coder (I'll do this off list unless directed otherwise).
gimpregionselecttool.c has this bit of code when selecting a region: /* don't let the events come in too fast, ignore below a delay of 100 ms */
if (time - last_time < 100)
return;
last_time = time;
diff_x = coords->x - region_sel->x; diff_y = coords->y - region_sel->y;
diff = ((ABS (diff_x) > ABS (diff_y)) ? diff_x : diff_y) / 2.0;
So there "if" doesn't look like it is too costly.
The way I came up with to avoid the "if" is (pseudo code):
X = x2-x1 Y = y2-y1
Z = [(X + Y) - ABS (X - Y)] / 2
So the upper left diagonal would go from x1,y1 to (x1 + Z), (y1 + Z)
Any advice on which way to implement?
Martin Nordholts
2007-11-11 10:00:01 UTC (over 17 years ago)
X = x2-x1 Y = y2-y1
We can keep this on-list so other people can jump in the they wish to.
From a performance point of view it is completely negligible to use an
if. The time it takes to do the actual rendering of a line is orders of magnitude larger than having a conditional statement when calculating what coordinates to use.
So the method of calculating what coordinates to use basically boils down to using the method that gives the most readable code, and I would say making use of an if is the most natural approach.
- Martin Nordholts
2007-11-12 21:29:50 UTC (over 17 years ago)
I didn't find that article very convincing. So I would like to get some positive feedback from artists before we add yet another Crop guides option.
Liam R E Quin
2008-02-04 23:13:05 UTC (about 17 years ago)
This has been a rule of composition since the Middle Ages. Probably I can find you some references. Tschicholde's page layout diagrams, and Leonardo's writing, may help.
But I am not sure that 45 degree lines from the corners of the crop rectangle would be sensible.
It might be better to allow diagonal guides, and have the corners of the crop box have a "snap to guides" behaviour, rather than build into the crop tool every possible kind of proportion.
You'd position the diagonals according to the image features, and then crop.
Liam
