problem (solved?) in gimp-plugin-template
12 of 12 messages available
problem (solved?) in gimp-plugin-template Carlo Baldassi 06 Nov 09:36
  problem (solved?) in gimp-plugin-template Sven Neumann 06 Nov 10:16
   problem (solved?) in gimp-plugin-template Michael Schumacher 06 Nov 11:26
problem (solved?) in gimp-plugin-template Carlo Baldassi 06 Nov 09:37
problem (solved?) in gimp-plugin-template Carlo Baldassi 10 Nov 05:59
  problem (solved?) in gimp-plugin-template Sven Neumann 10 Nov 16:38
problem (solved?) in gimp-plugin-template Carlo Baldassi 11 Nov 00:23
  problem (solved?) in gimp-plugin-template Sven Neumann 12 Nov 19:43
   problem (solved?) in gimp-plugin-template Michael Schumacher 12 Nov 21:47
problem (solved?) in gimp-plugin-template Carlo Baldassi 12 Nov 22:26
problem (solved?) in gimp-plugin-template Carlo Baldassi 12 Nov 22:49
  problem (solved?) in gimp-plugin-template Sven Neumann 12 Nov 23:19
Carlo Baldassi
2007-11-06 09:36:01 UTC (over 17 years ago)
I have developed a GIMP plugin using the plugin template, and I have been made aware of a problem in i18n support, which I think I solved: the plugin name was not translated correctly in the menu.
I think this is due to the fact that i18n is initialized in the run() function, while the plugin name is given in the query() function through a call to gimp_install_procedure().. What I did was just copy-pasting the i18n init code right before the gimp_install_procedure() call, and substituting "N_(...)" with "_(...)", like this:
/* Initialize i18n support */ bindtextdomain (GETTEXT_PACKAGE, LOCALEDIR); #ifdef HAVE_BIND_TEXTDOMAIN_CODESET
bind_textdomain_codeset (GETTEXT_PACKAGE, "UTF-8"); #endif
textdomain (GETTEXT_PACKAGE);
gimp_install_procedure (PROCEDURE_NAME, "Blurb",
"Help",
"Michael Natterer ",
"2000-2004",
_("Plug-In Template..."), "RGB*, GRAY*, INDEXED*", GIMP_PLUGIN,
G_N_ELEMENTS (args),
0,
args, NULL);
I don't know if the "N_(...)" call was meant to let it work, but in my system "gettex_noop()" is not defined, and "N_(...)" becomes "(...)" (don't know the reason of this). It seems to work well now, but I don't know if this procedure has any drawbacks (e.g. if initializing i18n twice gives any problem) or is incorrect for some reason.
Carlo Baldassi
___________________________________ L'email della prossima generazione? Puoi averla con la nuova Yahoo! Mail: http://it.docs.yahoo.com/nowyoucan.html
Carlo Baldassi
2007-11-06 09:37:01 UTC (over 17 years ago)
"Help",
"2000-2004",
0,
args, NULL);
Carlo Baldassi
2007-11-06 10:16:01 UTC (over 17 years ago)
This is not the correct solution. Instead the plug-in is supposed to use gimp_plugin_domain_register() to tell the GIMP core about the textdomain that the plug-in uses for translation. The core will then be able to translate the menu entry.
The rationale behind this is that the GIMP core needs to know the untranslated strings to correctly handle stuff like menu branches.
BTW, it would be nice if we could release an updated version of gimp-plugin-template for GIMP 2.4. Any volunteers to update the template in SVN?
2007-11-06 11:26:49 UTC (over 17 years ago)
Von: Sven Neumann
Here.
I have to figure out why (some) third-party plug-ins don't find their translations on Win32 anyway, and testing this with the plugin template would be a good place to start from.
Carlo Baldassi
2007-11-10 05:59:21 UTC (over 17 years ago)
still about porting plugins form 2.2 to 2.4:
use
textdomain
In fact, the call to gimp_domain_register() was already present in the gimp-plugin-template:
gimp_plugin_domain_register (PROCEDURE_NAME, LOCALEDIR);
It returns success, but the menu entry is not translated. I couldn't find any help from other plugins' sources because they don't register this way.
Another problem I found is that the GIMP helpbrowser doesn't read the help files correctly (no problem when using firefox, though). The crash occurs in helpbrowser/dialog.c, inside the function browser_dialog_make_index_foreach(), at this point:
indices = g_strsplit (item->title, ".", -1); /* THIS CALL FAILS */
for (i = 0; i < 5; i++) {
if (! indices[i]) /* CRASH HERE */ break;
item->index += atoi (indices[i]) << (8 * (5 - i)); }
and that's because item->title is NULL.
Thus, it seems that I need to register a title somehow, but I didn't find any documentation online about how to prepare an help file. Again, the standard plugins were of no help to me. Any help/hint/clue/link would be appreciated.
template
in SVN?
If I manage to get it tworking I would be glad to send you my patches!
Carlo
2007-11-10 16:38:11 UTC (over 17 years ago)
Does LOCALEDIR have the correct value? Are the translations actually installed in the folder that it points to?
I've fixed that last night; the fix will be in GIMP 2.4.2.
Your HTML help page needs to have a title, that's all.
Carlo Baldassi
2007-11-11 00:23:46 UTC (over 17 years ago)
the
Yes, I checked it directly. Everything else is localized, it's just the menu entry. In fact, the i18n initialization function uses the same location:
The HTML page does have a title:
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
Help Page for gimp-plugin-template
I have also tried to use one of the help pages from a standard plugin, as it was, just to test if I was missing some tag: same error.
Carlo
2007-11-12 19:43:57 UTC (over 17 years ago)
the
I checked again and it is the other parameter which is wrong:
This should be:
gimp_plugin_domain_register (GETTEXT_PACKAGE, LOCALEDIR);
If this is wrong in the plug-in template, then we should fix this and release an updated version as soon as possible.
2007-11-12 21:47:51 UTC (over 17 years ago)
Sven Neumann wrote:
This should be:
It is.
main.c:
HTH, Michael
Carlo Baldassi
2007-11-12 22:26:13 UTC (over 17 years ago)
This should be:
It is.
main.c:
Is there a more recent version of the plug-in-template I don't know of? I only found the one at ftp://ftp.gimp.org/pub/gimp/plugin-template/ and in that one the register line is wrong.
If so, the link at developer.gimp.org should be updated. Thanks
Carlo
Carlo Baldassi
2007-11-12 22:49:45 UTC (over 17 years ago)
It is.
Ooops, sorry, I didn't notice there was an SVN version of the template. It's the link on the sidebar of developer.gimp.org which points to the buggy version. Still, about the other bug, even with the SVN version the help file doesn't work with the helpbrowser in 2.4.1.
Carlo
2007-11-12 23:19:16 UTC (over 17 years ago)
We will release a fixed version of the plug-in template at some point in a not too distant future. Michael is already working on this.
As I said already, it should work fine with GIMP 2.4.2 when that is released. And that's only a matter of weeks, if not days only.
