2.4 and how to continue from here
Moin,
currently we are still fixing bugs in the 2.4.0 release but it seems that we caught the major problems now and want to prepare a 2.4.1 release soon. When that is done, we will immidiately create a gimp-2-4 branch to continue bug-fixing there.
At that point trunk will be open for development. But since we are aiming for a short development cycle, we need to absolutely keep the tree in a good shape. I don't want to see any commits that haven't been discussed and approved beforehand. This doesn't mean line-by-line code review. But I would like you guys to present your plans here beforehand and not learn about them from reading the commit logs.
So if are planning any particular features for 2.6, now is the time to present them here so that they can be put on the roadmap. This includes stuff that has been planned for quite a while, like for example finishing the metadata framework/editor (Raphael!), but also the port to GEGL (Mitch!).
I suggest that we keep brainstorming for the 2.6 roadmap for another week and then collect the ideas. It would be nice if we could end with a list of well-defined tasks. When that list is collected, I would like to discuss which of these tasks should be put on the roadmap for 2.6.
What are the plans for vector layers from GSoC 2006?
Alexandre
First of all I'm a Digital illustrator and 3d artist. GIMP in the actual state is great. My job can be done in 2.4 easily (thanks for the Jitter, scalable brushes and better zoom!). And I know that GEGL will be in the future of GIMP and the interface already have great proposals (and designers). So I decide to not propose these kind of features...
Ok, thats my feature request:
GIMP have a ease and very flexible way to create "animated brushes", with features like "Random" and "Angular" (to create brushes that "rotates" as you move in different angles). The thing is: If we have some of these features in the Tools Options for brushes will be more fast and ease to use the brushes that are not animated.
Some examples:
- The "Random" feature could be simple "rotating" (in its own axis) the original brush in a random way. Just a simple check box for activate it, maybe a intensity control how much is random.
- The "Angular" could also be activated using a Check Box. The angle of the brush changing as you drawn in different directions, dynamically rotating the brush. His "frequency" controlled by the "Space" option in the Brush Dialog.
- Other features that are avaible only creating animated Brushes could be in to. But these to are just great.
Other proposal for brushes are a option to control the Softness and Sharpness of Brushes. Today you need to create another brush just to change his "softness" (or hardness). Maybe a good alternative is to have in the Tools Options a "Slider" if two ways to go:
If you move the slider to the Left the brush will be "Sharpened"... to the Right will be Blurred. Here is a very ugly mockup:
http://fc03.deviantart.com/fs21/f/2007/302/f/a/very_ugly_mockup_by_Filsd.png
Thats it and thanks for the hard work.
I think you misunderstood me. This thread is not about sending your feature requests. It is about telling us what you would like to work on for the next time in GIMP. We already have more than enough feature requests. Please don't post more here but instead let the developers discuss what's important to address and what they would like to work on.
so as I've already written a few weeks ago in my mail about the new features for the text-tool in the PDB, I'd like to contribute especially in that part. As far as I understood the discussion about the roadmap, the PDB will get a little rework for the 2.6 release (named parameters, etc.).
So as I'm absolutely new to gimp-development, I'd like to know where is a good starting point to get all informations/things. I'm a bit confused about all information sources: mailing lists, web-pages, wikis, bugzilla, and the source-code itself of course, etc.
As Sven told me in a mail-reply, I should bring up the topic about the new text-tool PDB thing... So I have done it now ;)
best regards Marcus
It is nice of you to offer to work on improving the text tool portion of GIMP. This is one of those items that has needed work for sometime. It would be worth looking at the text tool related items in Bugzilla. The main (tracking) bug about text tool fixes and enhancement is bug #136740.
I saw, but haven't tried, the patch you sent to the mailing list. I see you are allowing extra text options to be set but it isn't easy to see what you are proposing. A new text tool API is one of the outstanding bug reports. It would be helpful to see a summary of the API changes you feel should be made in a form some along the lines of the PDB browser (ie. function name, arguments required, and values returned).
I have done a little bit of work on the text operation of GEGL and I know there can be a lot of parameters to set/get. Will you handle only some parameters now and others later? How would the extra parameters be handled later? Setting/getting all text parameters in one call may not be the best option. This may depend on the whether the PDB supported the use of named parameters when a new text tool API is being implemented.
Just some things to think about while you plan out a new text tool API. Hopefully, the next version of the text tool and its API will "get it right the first time". :-) Looking forward to the improvements you come up with.
I will continue working on GimpRectangleTool and I aim for more or less complete Selection + crop tool specification [1] conformance in 2.6.
- Martin Nordholts
[1] http://gui.gimp.org/index.php/Selection_%2B_crop_tool_specification
I plan to make iwarp into a tool.
--tml
I'd like to get a couple paint tool related patches in.
323921 GIMP NEW enh add support for color jitter in the paint tools 163050 GIMP NEW enh paint tools should support "smudging" as they paint.
Patches exist, though they haven't been tested against 2.4/2.5, I think they should apply pretty easily however. If theres interest, I can update them.
Adrian
A Monday 29 October 2007 16:24:11, Sven Neumann escreveu:
Hi Sevn and others,
I have been obn the process of moving myself to another city over the last few
weeks (almost complet now, just waiting for my mobile nad main machinne to
get here).
As soons as that happens I should consolidate my work hours and spare a few of
then for GIMP.
The feature I'd like to work on is a brush stroke pannel to be able to set up stroking with curves for relating pressure, speed, angle, etc with opacity, size, jitter, color, etc...
One other smallf eature I will want to add is the ability to add free- angled guides. I have this almost complete on my codebase, just .XCF saving for it is missing. I should commit that early on 2.6 cycle.
js ->
I would like to get some feedback from the UI team and from some artists on this. And of course the patch would have to be reviewed before it is committed. I am not yet convinced that this is an important feature and I also have the impression that it's just added ad-hoc without seeing the big picture. It certainly has the potential to cause a lot of problems.
Angled guides - was Re: 2.4 and how to continue from here
A Friday 09 November 2007 13:01:06, você escreveu:
I had never added a UI for it - I add then through scripts. And except for bugs with the guides thenselves (which i ironed out as I developed then), I never had any side effect from using them. Snapping to these guides or intesections of these guides and others works fine. If tehre are potential greater problems, just a larger userbase would be able to detect it, and then we just fix it, or remove the feature if it needs very large changes to other program areas to work properly.
And rest assured I would not commit it without having an ok from you first.
Of course I'd like more feedback from users and the UI team, but nearly everyone I had mentioned this had liked the idea. It is of little use in a program like GIMP where free handed drawing is not emphasized, but sometimes it is just nice it is there. (like for stamping a brush repeating it at a gven angle).
My idea for UI is just writing some code for the rotate tool to be able to rotate guides, just as the move tool can move guides. i think that once tested this won't get in anyone's path and will be a little nice feature for GIMP.
regards,
js
Arbitrary angle guides would be really useful for visual aligning layers/selections along imaginary angled line. But only if precise rotation of the guide is possible. And there might be a technical challenge to implement visual moving of angled guide? same way we do it now with hor/vert guides. Anyway, expect a lot of feedback from me if this feature will have green light :) and please share your scripts if it's not ;)
Alexandre
Without a user interface for it, there is zero user base. And most problems are detected only after a feature is released in a stable release. And at that point it is too late to fix a fundamental design problem.
Perhaps I should just review the patch before we continue. But in the meantime someone should think about the user interface for this. Without one, it is pointless to add this.
resending...
Sven wrote,
is missing. I should commit that early on 2.6 cycle.I would like to get some feedback from the UI team and from some artists
yeah. Kamila came up with the plan for rotating guides and I could see then how it could have an impact on for instance web design by breaking the normal hor/vert grid.
and after a few minutes I could come up with a decent on-screen UI.
but the real question is the priority of this yet-another-feature. something like geometry tools integration has a much higher priority than this.
--ps
A Sunday 11 November 2007 20:48:27, peter sikking escreveu:
There eason I proposed this at this stage is that I have this feature complete minus UI and XCF saving in my GIMP tree. It has been like that for over an year when I was told it was too late to make it into gimp 2.4.
js ->
