pushing color management further
pushing color management further Sven Neumann 27 Oct 21:51
  pushing color management further Alastair M. Robinson 28 Oct 00:17
2007-10-27 21:51:48 UTC (over 17 years ago)
Moin,
another task that should be put on the agenda, perhaps even for 2.6:
Currently only the image display is color-managed. The color selectors and the previews in the core and in plug-ins aren't. This should be changed and it should be possible to reuse the existing ColorDisplay filters to do this job.
Reusing the display filters for this is probably the way to go. We would hovever have to make an optimization in the lcms module then. Currently each display filter loads the color profiles and creates a transformation object to convert between colorspaces. If we extend this to all previews and color selectors, then we will have to avoid this. So either we reuse the same display filter for all previews or we introduce a transformation cache. Perhaps doing both would be the best solution as multiple displays on the same image would also benefit from a transformation cache.
If anyone wants to work on this, please talk to me. I have some more thoughts spent on this already. So far I only wanted to have this brought up so that it isn't forgotten....
2007-10-28 00:17:26 UTC (over 17 years ago)
I've implemented a Transform Cache in PhotoPrint - I think I've mentioned before that as a "signature" for matching the correct transform I use an MD5 hash of both source and destination profiles (excluding headers), as well as the rendering intent. Just throwing that in, in the hope it might be useful.
All the best, --
