crop tool's little annoyance
crop tool's little annoyance Alexandre Prokoudine 23 Oct 15:54
  crop tool's little annoyance Martin Nordholts 23 Oct 19:49
   crop tool's little annoyance Alexandre Prokoudine 23 Oct 20:56
    crop tool's little annoyance Martin Nordholts 23 Oct 23:21
2007-10-23 15:54:58 UTC (over 17 years ago)
It looks like there is a small regression of Crop tool's behaviour as of svn trunk: if you draw a relatively small selection (size matters only for better ) and start switching portrait/landscape mode, the selection grows until it fits width/height of the image by either side. That doesn't look like a intentionally designed feature.
Alexandre
Martin Nordholts
2007-10-23 19:49:20 UTC (over 17 years ago)
Hello
I am unable to reproduce this, for what ratio and rectangle size does this occur?
- Martin Nordholts
2007-10-23 20:56:38 UTC (over 17 years ago)
3:2, 4:3
Alexandre
Martin Nordholts
2007-10-23 23:21:12 UTC (over 17 years ago)
3:2, 4:3
Alexandre
Seems to be an integer rounding issue. I have planned to change internal rectangle coordinates to doubles for 2.5/2.6 to fix a bunch of other rounding-related errors I have noted, and this bug should be indirectly solved then as well.
- Martin Nordholts
