calling a procedure in a plugin
15 of 15 messages available
calling a procedure in a plugin Giuseppe Pasquino 16 Oct 13:04
  calling a procedure in a plugin Aurimas Juška 16 Oct 16:02
   calling a procedure in a plugin Giuseppe Pasquino 16 Oct 16:39
   calling a procedure in a plugin Sven Neumann 17 Oct 20:34
  calling a procedure in a plugin Sven Neumann 17 Oct 20:32
   calling a procedure in a plugin Giuseppe Pasquino 18 Oct 11:59
    calling a procedure in a plugin Aurimas Juška 18 Oct 12:06
     calling a procedure in a plugin Giuseppe Pasquino 18 Oct 14:14
      calling a procedure in a plugin Sven Neumann 18 Oct 14:32
       calling a procedure in a plugin Giuseppe Pasquino 18 Oct 15:05
        calling a procedure in a plugin Sven Neumann 18 Oct 15:13
         calling a procedure in a plugin Giuseppe Pasquino 19 Oct 11:00
          calling a procedure in a plugin David Gowers 19 Oct 11:27
           calling a procedure in a plugin Giuseppe Pasquino 19 Oct 11:37
calling a procedure in a plugin Giuseppe Pasquino 16 Oct 14:22
Giuseppe Pasquino
2007-10-16 13:04:26 UTC (over 17 years ago)
Hello, I'm working on this plugin: after few operations, it picks a color from the image (with che function gimp_pixel_rgn_get_pixel) to get the guchar value of the components of the related color. At this point, I need to call the "gimp_by_color_select" procedure but I'm not sure to follow the right way... Anyone can help me? How do I manage the guchar values to convert in GimpRGB?
Thanks a lot to all and sorry for my bad English (I'm italian)...
Giuseppe.
__________________
Giuseppe Pasquino
2007-10-16 14:22:23 UTC (over 17 years ago)
Hello, I'm working on this plugin:after few operations, it picks a color from the image (with che function gimp_pixel_rgn_get_pixel) to get the guchar value of the components of the related color.At this point, I need to call the "gimp_by_color_select" procedure but I'm not sure to follow the right way... Anyone can help me? How do I manage the guchar values to convert in GimpRGB?Thanks a lot to all and sorry for my bad English (I'm italian)...Giuseppe. __________________
Aurimas Juška
2007-10-16 16:02:15 UTC (over 17 years ago)
http://developer.gimp.org/api/2.0/libgimp/libgimp-gimp.html#gimp-run-procedure
Procedure parameters: http://www.goof.com/pcg/marc/pdb/gimp_by_color_select.html
But it is generally easier to lookup params in procedure browser.
Giuseppe.
________________________________ Con Windows Live Messenger condividi file senza limiti di peso! Windows Live Messenger
Giuseppe Pasquino
2007-10-16 16:39:15 UTC (over 17 years ago)
Thanks for your help... I have another question: how can I convert a guchar value taken by "gimp_pixel_rgn_get_pixel" to COLOR?
Date: Tue, 16 Oct 2007 17:02:15 +0300> From: aurimas.juska@gmail.com> To: giuseppepasquino@hotmail.com> Subject: Re: [Gimp-developer] calling a procedure in a plugin> CC: gimp-developer@lists.xcf.berkeley.edu> > http://developer.gimp.org/api/2.0/libgimp/libgimp-gimp.html#gimp-run-procedure> > Procedure parameters:> http://www.goof.com/pcg/marc/pdb/gimp_by_color_select.html> > But it is generally easier to lookup params in procedure browser.
__________________
2007-10-17 20:32:24 UTC (over 17 years ago)
Just use the C wrapper. Have a look at the API reference manual, it's all nicely documented:
http://developer.gimp.org/api/2.0/libgimp/libgimp-gimptools.html#id2678685
http://developer.gimp.org/api/2.0/libgimpcolor/libgimpcolor-GimpRGB.html#gimp-rgb-set-uchar
2007-10-17 20:34:34 UTC (over 17 years ago)
Thanks for your attempt to help. But please don't point people to the outdated PDB documentation at Marc's website. It hasn't been updated for ages and we have a nice API reference manual online at http://developer.gimp.org/.
Giuseppe Pasquino
2007-10-18 11:59:29 UTC (over 17 years ago)
Thanks to all for the useful help... I'll write this function but it return a fatal error (SEGMENTATION FAULT) and it don't make the selection... Here is the code:
static void evidenzia (GimpDrawable *drawable, GimpPreview *preview){ gint width, height; //dell'immagine su cui va applicato il plugin gint altezza, larghezza; //numero di pixel formanti la palette gint x1, x2, y1, y2; GimpPixelRgn rgn_in, rgn_out; guchar pixel[4]; guchar colore[3]; gint i, channels; gint distanza; GimpParam *return_vals; gint nreturn_vals; if (preview) return; else gimp_progress_init ("Evidenzia Temperatura..."); //Recupero del drawable gimp_drawable_mask_bounds (drawable->drawable_id, &x1, &y1, &x2, &y2); width = x2 - x1; height = y2 - y1; /* Inizializza due PixelRgns, uno per leggere i dati originali, * e l'altro per scrivere i dati modificati. Il secondo sarà * poi applicato all'immaginne alla fine attraverso la chiamata * gimp_drawable_merge_shadow() */ gimp_pixel_rgn_init (&rgn_in, drawable, x1, y1, width, height, FALSE, FALSE); gimp_pixel_rgn_init (&rgn_out, drawable, x1, y1, width, height, preview == NULL, TRUE); //Recupero del numero di canali channels = gimp_drawable_bpp (drawable->drawable_id); //Calcolo delle dimensioni della palette altezza = termogramma.palettey2 - termogramma.palettey1; larghezza = termogramma.palettex2 - termogramma.palettex1; /* * Se l'altezza è più grande della larghezza allora vuol dire che la palette è disposta in verticale. * Se succede il contrario allora la palette è disposta in orizzontale */ if(altezza > larghezza) { //g_print("1\n"); altezza //g_print("2\n"); debug distanza = (termogramma.tempselezionata - termogramma.tempmin) * larghezza / (termogramma.tempmax - termogramma.tempmin); //Ottengo il pixel corrispondete (coordinate (x1 + distanza), y1 + (y2 - y1)/2) gimp_pixel_rgn_get_pixel(&rgn_in, pixel, termogramma.palettex1 + distanza, termogramma.palettey1 + (termogramma.palettey2 - termogramma.palettey1)/2); //g_print("%i, %i", termogramma.palettex1 + distanza, termogramma.palettey1 + (termogramma.palettey2 - termogramma.palettey1)/2); debug } for(i = 0; i < 3; i++) colore[i] = pixel[i]; return_vals = gimp_run_procedure("gimp_by_color_select", &nreturn_vals, GIMP_PDB_DRAWABLE, drawable, //drawable GIMP_PDB_COLOR, colore, //color GIMP_PDB_INT32, termogramma.scarto, //threshold GIMP_PDB_INT32, 2, //operation GIMP_PDB_INT32, 0, //antialiasing GIMP_PDB_INT32, 0, GIMP_PDB_INT32, 0, GIMP_PDB_FLOAT, 0.0, GIMP_PDB_INT32, 0); }
What's wrong with this code?
__________________
Aurimas Juška
2007-10-18 12:06:54 UTC (over 17 years ago)
gimp_run_procedure() is not properly terminated with GIMP_PDB_END (see documentation). Again, as Sven said, use c wrappers if they are available for procedure that you need.
static void evidenzia (GimpDrawable *drawable, GimpPreview *preview) {
guchar colore[3];
gint i, channels;
gint distanza;
gint nreturn_vals;
height = y2 - y1;
GIMP_PDB_INT32, 0);
________________________________ Sfida i tuoi amici in entusiasmanti sfide con i giochi di Messenger! Messenger Giochi
Giuseppe Pasquino
2007-10-18 14:14:43 UTC (over 17 years ago)
Ok, I'll modify the plugin in this way: static void evidenzia (GimpDrawable *drawable, GimpPreview *preview) {
guchar colore[3];
gint i, channels;
gint distanza;
gint nreturn_vals;
gboolean success;
height = y2 - y1;
if(altezza> larghezza) {
g_print("1\n");
//Ottengo il colore alla temperatura specificata. Lo faccio facendo una media tra tutti i colori che si trovano sulla stessa riga distanza = (termogramma.tempselezionata - termogramma.tempmin) * altezza / (termogramma.tempmax - termogramma.tempmin); //Ottengo il pixel corrispondente (coordinate x1 + (x2 - x1)/2, (y2 - distanza)) gimp_pixel_rgn_get_pixel(&rgn_in, pixel, termogramma.palettex1 + (termogramma.palettex2 - termogramma.palettex1)/2, termogramma.palettey2 - distanza); g_print("%i, %i\n", termogramma.palettex1 + (termogramma.palettex2 - termogramma.palettex1)/2, termogramma.palettey2 - distanza); }
else {//larghezza> altezza
g_print("2\n");
distanza = (termogramma.tempselezionata - termogramma.tempmin) * larghezza / (termogramma.tempmax - termogramma.tempmin); //Ottengo il pixel corrispondete (coordinate (x1 + distanza), y1 + (y2 - y1)/2) gimp_pixel_rgn_get_pixel(&rgn_in, pixel, termogramma.palettex1 + distanza, termogramma.palettey1 + (termogramma.palettey2 - termogramma.palettey1)/2); g_print("%i, %i\n", termogramma.palettex1 + distanza, termogramma.palettey1 + (termogramma.palettey2 - termogramma.palettey1)/2); }
for(i = 0; i < 3; i++) {
colore[i] = pixel[i]; g_print("%i ",colore[i]); }
return_vals = gimp_run_procedure ("gimp-by-color-select", &nreturn_vals, GIMP_PDB_DRAWABLE, drawable->drawable_id, GIMP_PDB_COLOR, pixel, GIMP_PDB_INT32, termogramma.scarto, GIMP_PDB_INT32, 2, GIMP_PDB_INT32, FALSE, GIMP_PDB_INT32, FALSE, GIMP_PDB_FLOAT, 0.0, GIMP_PDB_INT32, FALSE, GIMP_PDB_END);
success = return_vals[0].data.d_status == GIMP_PDB_SUCCESS; //si distruggono i parametri per liberare la memoria gimp_destroy_params (return_vals, nreturn_vals); if(success) g_print("Fatto\n");
the variable success is TRUE after calling the procedure but it select every black pixel instead the values contained in the "colori" vector. It' is a bug or I'm make some mistakes?
__________________
2007-10-18 14:32:05 UTC (over 17 years ago)
why don't you just do what we suggested? If you would use gimp_by_color_select() instead of gimp_run_procedure(), the compiler would be able to tell you that your code is buggy.
Giuseppe Pasquino
2007-10-18 15:05:15 UTC (over 17 years ago)
Because I have problem converting the guchar vector for the color in "GimpRGB" and I don't know how manage with GimpChannelOps... Can you write me down an example?
----------------------------------------> Subject: RE: RE: [Gimp-developer] calling a procedure in a plugin> From: sven@gimp.org> To: giuseppepasquino@hotmail.com> CC: gimp-developer@lists.xcf.berkeley.edu> Date: Thu, 18 Oct 2007 14:32:05 +0200>> Hi,>> why don't you just do what we suggested? If you would use> gimp_by_color_select() instead of gimp_run_procedure(), the compiler> would be able to tell you that your code is buggy.>>> Sven>>
__________________
2007-10-18 15:13:11 UTC (over 17 years ago)
I think I already pointed you to the API reference for GimpRGB and gimp_rgb_set_uchar() in particular. GimpChannelOps is an enum and the possible values are listed in the API reference. Just follow the link.
You can also save yourself the hassle of working with pixel regions if all you want to do is to get the color of a single pixel. There's gimp_drawable_get_pixel() for that purpose.
Giuseppe Pasquino
2007-10-19 11:00:41 UTC (over 17 years ago)
I have modified the code as you suggested:
GimpRGB *colore; GimpChannelOps parametri;
gboolean success;
gimp_rgb_set_uchar(colore, pixel[0], pixel[1], pixel[2]); parametri = GIMP_CHANNEL_OP_REPLACE; success = gimp_by_color_select(drawable->drawable_id, colore, termogramma.scarto, parametri, FALSE, FALSE, 0.0, FALSE);
The compiler returns me no error but when I execute the gimp return a fatal error: "segmentation fault". I think the problem is in one of this line but, with my few experience, I can't find it...
Sven>>
__________________
David Gowers
2007-10-19 11:27:48 UTC (over 17 years ago)
gboolean success;
You are attempting to modify a color at some random memory location, that's never been allocated (you didn't initialize colore) -- and then you passed this dodgy pointer to gimp_by_color_select.
In most parts of the GIMP, GimpRGB are statically allocated, and you see that they are used more like this:
GimpRGB colore; GimpChannelOps parametri;
gboolean success;
gimp_rgb_set_uchar(&colore, pixel[0], pixel[1], pixel[2]); parametri = GIMP_CHANNEL_OP_REPLACE; success = gimp_by_color_select(drawable->drawable_id, &colore, termogramma.scarto, parametri, FALSE, FALSE, 0.0, FALSE);
Giuseppe Pasquino
2007-10-19 11:37:06 UTC (over 17 years ago)
Thanks to all... Now it's work...
You are attempting to modify a color at some random memory location, that's never been allocated (you didn't initialize colore) and then you passed this dodgy pointer to gimp_by_color_select. In most parts of the GIMP, GimpRGB are statically allocated, and you see that they are used more like this:
GimpRGB colore;
gboolean success;
__________________
