Is there anything like a gimp_drawable_zoom_preview ?
Is there anything like a gimp_drawable_zoom_preview ? Jean Tourrilhes 15 Oct 21:42
  Is there anything like a gimp_drawable_zoom_preview ? Sven Neumann 15 Oct 22:06
   Is there anything like a gimp_drawable_zoom_preview ? Jean Tourrilhes 15 Oct 22:17
    Is there anything like a gimp_drawable_zoom_preview ? Sven Neumann 15 Oct 22:23
Jean Tourrilhes
2007-10-15 21:42:04 UTC (over 17 years ago)
Sorry to disturb you all... I'm using a plugin that has a preview in its main window. The preview is so small on my screen that I can't really see any of the adjustements. So, I would like to optionally make the preview bigger. I had a quick look at the code and the documentation. At first glance, it would seem that I would need to replace the "gimp_drawable_preview" with the "gimp_zoom_preview". However, the preview is updated via gimp_drawable_preview_draw_region(), and this call does not seem to exist for the "gimp_zoom_preview".
So, I guess I would need to combine the "gimp_drawable_preview" and "gimp_zoom_preview" in some fashion, or find if there exist a "gimp_drawable_zoom_preview" object. Does anybody has some useful suggestions ?
Thanks in advance...
Jean
2007-10-15 22:06:55 UTC (over 17 years ago)
Using a zoomable preview is somewhat more difficult than using a GimpDrawablePreview. You can't just do search and replace and expect this to work. I suggest that you have a look at some of the plug-ins in the 2.4 source tree that use it.
Jean Tourrilhes
2007-10-15 22:17:26 UTC (over 17 years ago)
On Mon, Oct 15, 2007 at 10:06:55PM +0200, Sven Neumann wrote:
Thanks for the *very* quick answer, that's appreciated.
That's unfortunate.
Note that I personally believe that all GimpDrawablePreview should be zoomable, but it's probably because I've been using high resolutions display for too long.
I'll look into that, if I can find time. Or the alternative is to scale up the region before pusing it to the GimpDrawablePreview.
Have fun...
Jean
2007-10-15 22:23:59 UTC (over 17 years ago)
That is why we introduced GimpZoomPreview. It's just that, a drawable preview with zoom capabilities.
Which is what you would do with GimpZoomPreview. The main purpose of GimpZoomPreview is to provide the infrastructure to display a scaled preview. It's still up to you do actually provide it the scaled data. But why don't you just look at the code? That would help a lot more than speculating about it.
