how to convert gimps xcf format to pdf..
how to convert gimps xcf format to pdf.. Pcdokteraanhuis 08 Oct 09:35
  how to convert gimps xcf format to pdf.. rcook@pcug.org.au 08 Oct 09:54
  how to convert gimps xcf format to pdf.. Alexandre Prokoudine 08 Oct 09:54
   how to convert gimps xcf format to pdf.. stefan.roellin@gmx.ch 08 Oct 21:39
  how to convert gimps xcf format to pdf.. Sven Neumann 08 Oct 21:59
Pcdokteraanhuis
2007-10-08 09:35:54 UTC (over 17 years ago)
I am a new user off GIMP and I like it..
but how canI how to convert gimps xcf format to pdf..
rgds
Patrick
rcook@pcug.org.au
2007-10-08 09:54:03 UTC (over 17 years ago)
If you are using windows, I don't know, but on a linux system you could try a two part process, save as tiff or ps and then use tiff2pdf or one of the ps2pdf programs
Owen
2007-10-08 09:54:20 UTC (over 17 years ago)
First and foremost this is the wrong list for this question. Please use gimp-user@ next time.
Second, print it to PDF
Alexandre
2007-10-08 21:39:33 UTC (over 17 years ago)
I started to write a plugin for gimp that allows to save an image directly to PDF. At the moment, each layer is stored separately in the PDF (compared to "print to PDF"). Text layers are not stored as selectable text but as an image layer.
The plugin already works but needs some polish, before I will submit it. I try to work on it during the next couple of weeks.
Stefan
2007-10-08 21:59:51 UTC (over 17 years ago)
File->Print, then choose to print to file and select PDF as output format. This requires GIMP 2.4.
