gimp and dbus
gimp and dbus Yves de Champlain 27 Sep 01:25
  gimp and dbus Sven Neumann 27 Sep 08:59
   gimp and dbus Yves de Champlain 27 Sep 18:10
    gimp and dbus Sven Neumann 27 Sep 21:21
Yves de Champlain
2007-09-27 01:25:40 UTC (over 17 years ago)
gimp and dbus
Hi
Sorry if I'm asking a stupid question ...
Is it possible to compile gimp with dbus support without having to use dbus-lauch to launch it ?
thanks
yves
2007-09-27 08:59:57 UTC (over 17 years ago)
gimp and dbus
d-bus support only makes sense if you are on a desktop that already runs a session bus. The GNOME desktop environment for example provides this. So if that is not the case for you, then you should probably compile without d-bus support.
We might not have tested this good enough. Are there any problems running an executable that is compiled with d-bus support on a desktop without a session bus?
Yves de Champlain
2007-09-27 18:10:43 UTC (over 17 years ago)
gimp and dbus
My problem is, in fact, thatI don't really know dbus and how it works, but I maintain gimp for macports and I usually try to go with the app's default settings.
Now, if I get it right, it should work if, for example, I am running gimp inside a dbus-launched gnome-session ?
I do have a dbus-daemon running but it does not seem sufficient. I get
yves$ gimp-2.4 process 16616: D-Bus library appears to be incorrectly set up; failed to read machine uuid: Failed to open "/opt/local/var/lib/dbus/machine- id": No such file or directory
So I replaced the gimp symlink with a little script that just does "dbus-launch gimp-2.4" but I am considering to make dbus an option rather than a default in macports.
Do you have an opinion about this ?
Thanks
yves
2007-09-27 21:21:07 UTC (over 17 years ago)
gimp and dbus
I suggest that you explicitely disable d-bus support then. There's a configure option for this.
