Mac OX X menus gone where ?
7 of 8 messages available
Mac OX X menus gone where ? Yves de Champlain 11 Sep 13:32
  Mac OX X menus gone where ? Ben Goodger 11 Sep 15:51
   Mac OX X menus gone where ? Yves de Champlain 12 Sep 00:00
   Mac OX X menus gone where ? Michael Natterer 12 Sep 22:17
  Mac OX X menus gone where ? Sven Neumann 12 Sep 08:44
   Mac OX X menus gone where ? Yves de Champlain 12 Sep 15:17
mailman.107307.1189573454.1... 07 Oct 20:25
  Mac OX X menus gone where ? M. Gagnon 12 Sep 15:51
Yves de Champlain
2007-09-11 13:32:55 UTC (about 18 years ago)
Hi
I read in the NEWS :
Changes in GIMP 2.4.0-rc2 =========================
- on OS X, get rid of menubars in windows and use the global menubar
Either I don't know what the gloal menu bar is, either it is not wotking because I don't have any Gimp menu anywhere.
Mac OS X 10.4.10 PPC XFree86 4.7.0
X11.app
quartz-wm
thanks
yves
Ben Goodger
2007-09-11 15:51:41 UTC (about 18 years ago)
You must know where the global menu bar is. It's the big white thing at the top with the menus on it. Starting in 2.4.0-rc2, GIMP on OSX no longer has an Xorg-style menu per window but instead uses OSX's native thingibob.
Yves de Champlain
2007-09-12 00:00:00 UTC (about 18 years ago)
Le 07-09-11 à 09:51, Ben Goodger a écrit :
On 11/09/2007, Yves de Champlain wrote: Either I don't know what the gloal menu bar is, either it is not wotking
Well, that is what I thought, so it does not work for me. All I see is X11.app's menu.
BTW, what happens in rootless mode ?
yves
2007-09-12 08:44:53 UTC (about 18 years ago)
X11.app
quartz-wm
You won't get the global menu bar unless you use GTK+ compiled with the (experimental) Quartz backend. The fact that you don't get any image menu with GTK+ compiled for X11 is indeed a bug in GIMP that should be fixed with the next release.
Yves de Champlain
2007-09-12 15:17:46 UTC (about 18 years ago)
X11.app
quartz-wm
Thanks for the tip.
Does that mean that GTK+ / quartz is advanced enough to make a usable GIMP ?
yves
M. Gagnon
2007-09-12 15:51:53 UTC (about 18 years ago)
Actually, it is because there are 2 ways to install GTK+ on OS X. X11.app, and Imendio's native port (found on gtk.org, on the menu on the left). They implemented a native menu bar for Imendio's port, but broke the X11.app version along the way - eventually Imendio's quartz backend will totally replace X11.app for everything GTK but you're right that until it's stable i think breaking the X11 version is bad. I don't know how to check which one we're using though, but there may be some defines for that. __________________
Michael Natterer
2007-09-12 22:17:48 UTC (about 18 years ago)
Right, but it should only do that if compiled against the GDK quartz backend, and not if compiled against X11. RC2 on X11 on OS X has no menus at all. This is a bug and makes it unusable.
Use RC1 instead or wait for RC3, the bug is already fixed in SVN.
ciao, --mitch
