Print Dialog - Seg faults in 2.4RC1
Print Dialog - Seg faults in 2.4RC1 Tim Jedlicka 27 Aug 06:31
  Print Dialog - Seg faults in 2.4RC1 Akkana Peck 27 Aug 06:53
  Print Dialog - Seg faults in 2.4RC1 Michael Schumacher 27 Aug 11:34
Tim Jedlicka
2007-08-27 06:31:12 UTC (over 17 years ago)
When I select the "Print" button, I get a segmentation fault: /opt/gimp-2.4/lib/gimp/2.0/plug-ins/print: fatal error: Segmentation fault
I'm guessing I'm missing something basic. I downloaded and compiled gtk+- 2.10.13, then compiled gimp2.4rc1 with PKG_CONFIG_PATH set to include the gtk2.10.13 package.
Anything obvious I should check.
Akkana Peck
2007-08-27 06:53:51 UTC (over 17 years ago)
Tim Jedlicka writes:
I saw that too, a few weeks ago, but didn't report it because I'm using an older gtk library and I thought that could be the problem.
But on current SVN, I no longer see a crash. So whatever the problem was, it seems to be fixed.
...Akkana
2007-08-27 11:34:01 UTC (over 17 years ago)
Von: "Tim Jedlicka"
Bugzilla - http://bugzilla.gnome.org/browse.cgi?product=GIMP. It might also be useful to watch the Bugzilla user "bugs(at)gimp.org", you will then receive mail notifications of changes (granularity is configurable) to bugs in the GIMP product.
You would most likely have noticed bug http://bugzilla.gnome.org/show_bug.cgi?id=467643 or one of its duplicates then.
HTH, Michael
