troubles with release candidate
5 of 6 messages available
troubles with release candidate jmt 25 Aug 12:27
  troubles with release candidate Martin Nordholts 25 Aug 12:58
200708251603.22758.jmt@remo... 07 Oct 20:25
  troubles with release candidate Martin Nordholts 25 Aug 16:27
   troubles with release candidate jmt 25 Aug 21:21
    troubles with release candidate Martin Nordholts 25 Aug 21:40
jmt
2007-08-25 12:27:01 UTC (over 17 years ago)
The recent release candidate crashes with a segmentatin fault on my debian amd64 box.
I have a first version in a chroot with debian amd64 unstable, using the latest svn sources, and a second version retrieved as a debian package (2.4.0~rc1-4).
Both crash miserabily when I try to resize windows, or zoom in or zoom out, or sometimes quite randomly.
Tracing execution gives no tip, at least for me :
... write(3, "\224\3\n\0004\6 \4\215\2 \4\0\6@\0\0\0\0\0\0\1@\0\215\1"..., 244) = 244
read(3, "\1\0024A\0\0\0\0W\2 \4\0\0\0\0\304\6~\0\0\0\0\0\320!76"..., 32) = 32 write(3, "\224\3\n\0004\6 \4\215\2 \4\0\6@\0\0\0\0\0\0\1@\0\215\0"..., 244) = 244
read(3, "\1\2;A\0\0\0\0W\2 \4\0\0\0\0\304\6~\0\0\0\0\0\320!76\377"..., 32) = 32
--- SIGSEGV (Segmentation fault) @ 0 (0) --- +++ killed by SIGSEGV +++
Process 8711 detached
(script-fu:8718): LibGimpBase-WARNING **: script-fu: gimp_wire_read(): error
Has anyone already encountered this ?
jmt
Martin Nordholts
2007-08-25 12:58:43 UTC (over 17 years ago)
Hello
Please provide a stacktrace from the current SVN version, and what GTK+ version you run.
- Martin Nordholts
Martin Nordholts
2007-08-25 16:27:54 UTC (over 17 years ago)
jmt wrote:
When I build with revision 23281, I do not have theses crashes.
Great, problem solved.
- Martin
jmt
2007-08-25 21:21:49 UTC (over 17 years ago)
- Martin
Crashes now when drawing pathes, revision 23375.
Martin Nordholts
2007-08-25 21:40:59 UTC (over 17 years ago)
- Martin
Please be more specific when you report bugs.
If you report a bug at bugs.gimp.org you will be asked the question we would like you to answer.
I tried to create some paths in current SVN trunk, but it didn't crash for me, so you will need to provide detailed description of how to reproduce it.
Obvious bugs are best reported at bugs.gimp.org instead of to the mailing list.
- Martin
