View resampling quality and performance
View resampling quality and performance Øyvind Kolås 22 Aug 17:04
Øyvind Kolås
2007-08-22 17:04:01 UTC (over 17 years ago)
The code used for showing the image has been changed quite a bit recently. The first modification was that addition of a mipmap pyramid implemented on the tile level that acts as a foundation for more efficient redraws that no longer needs to traverse all the data of the image at full resolution to redisplay it when zoomed out. In 2.4rc1 yielding a performance increase (assuming that the code does indeed cache results between levels correctly.)
For 2.4rc1 I added code that did something close to bilinear interpolation from the next larger mipmap level, this yielded even better results at a slight performance penalty. (There might also be a crasher bug introduced for some image size/display size combinations, not fully sure about this though).
In current SVN I've committed code that implements a box-filter that uses a 3x3 neighborhood instead of the 2x2 neighborhood that the bilinear filter used, there still are room for some improvements both to the code readability as well as the performance of the re sampling.
For many common resolutions these changes should have no impact on the speed compared to the plain pyramid (100%, 50%, 25%, since nearest neighbour re sampling is used directly on the correct pyramid level). It is possible with this implementation to enable anti aliasing between the rectangles representing pixels at zoom levels > 100% using this code, I am not sure if this is desired or not, I have thus left it without anti aliasing in these cases.
If others want to help clean up as well as optimize the code, the places to look are in app/display/gimpdisplayshell-render.c
The innermost function is compute_sample() , this function should be modified to be as fast as possible since it is the piece of code called most of the time. The shifting being done is done to avoid some integer overflowing issues; it would be nice if these issues could be resolved, there are also some other comments about possible optimizations/reorganization of the code possible here in comments within the function.
render_image_tile_fault() this function is a generic function implementing the 3x3 neighbourhood traversal needed for the box filter, this code should probably focus on readability instead of performance since it will most of the time be handing off the actual work to either render_image_tile_fault_nearest or render_image_tile_fault_one_row, render_image_tile_fault_one_row() is the image iteration and tile traversal code that is called for the most common case (all pixels needed can be fetched from a single row of tiles.) Reducing the overhead (number of tiles kept in memory, etc.) for this function will result in a faster display.
A general optimization that hasn't been done yet on a more architectural level would be moving the projection to use pre-multiplied alpha, this would remove the premultiply and un-premulitply steps for each level of the pyramid as well as
the scaled blit itself, thankfully when I start migrating this last piece of box-filtering code back to GEGL again I already have that, and thus should be able to do slightly faster scaled blitting from the pyramid.
/Øyvind K.
