Extending GIMP Plugins
Extending GIMP Plugins | Amit Kumar Saha | 21 Aug 12:18 |
Extending GIMP Plugins | Michael Schumacher | 21 Aug 15:55 |
Extending GIMP Plugins | Michael J. Hammel | 21 Aug 17:06 |
Extending GIMP Plugins | Amit Kumar Saha | 21 Aug 19:13 |
Extending GIMP Plugins | Karl Günter Wünsch | 21 Aug 18:09 |
Extending GIMP Plugins | Martin Nordholts | 21 Aug 17:57 |
Extending GIMP Plugins | Amit Kumar Saha | 21 Aug 19:18 |
Extending GIMP Plugins | Kevin Cozens | 21 Aug 17:29 |
Extending GIMP Plugins | Amit Kumar Saha | 21 Aug 19:20 |
Extending GIMP Plugins | Amit Kumar Saha | 22 Aug 19:32 |
Extending GIMP Plugins | Michael Schumacher | 22 Aug 23:55 |
Extending GIMP Plugins | David Marrs | 23 Aug 00:19 |
Extending GIMP Plugins | Renan Birck | 23 Aug 00:56 |
Extending GIMP Plugins | Kevin Cozens | 23 Aug 04:14 |
Extending GIMP Plugins | Amit Kumar Saha | 23 Aug 04:17 |
Extending GIMP Plugins | Amit Kumar Saha | 25 Aug 20:22 |
Extending GIMP Plugins | David Gowers | 26 Aug 03:38 |
Extending GIMP Plugins | Amit Kumar Saha | 26 Aug 18:26 |
Extending GIMP Plugins | Øyvind Kolås | 27 Aug 10:34 |
Extending GIMP Plugins | Amit Kumar Saha | 27 Aug 15:18 |
Extending GIMP Plugins | Kevin Cozens | 27 Aug 16:16 |
Extending GIMP Plugins | Raphaël Quinet | 23 Aug 01:03 |
Extending GIMP Plugins | Amit Kumar Saha | 25 Aug 12:19 |
Extending GIMP Plugins | gg@catking.net | 25 Aug 13:16 |
Extending GIMP Plugins | Amit Kumar Saha | 25 Aug 13:35 |
Extending GIMP Plugins | David Hodson | 25 Aug 16:16 |
Extending GIMP Plugins | Kevin Cozens | 25 Aug 16:38 |
Extending GIMP Plugins | Øyvind Kolås | 23 Aug 01:36 |
Extending GIMP Plugins | Raphaël Quinet | 22 Aug 23:50 |
Hello all,
GIMP plugins extend GIMP, we know that.
Is there any way to make GIMP plugins themselves extensible. My point here is that, can we make a GIMP plugin which allows itself modifiable by a end-user to include a new functionality without much of a hassle on part of the end-user. Does any one know of a method to do this or any GIMP plugin which already does this?
I would appreciate even the slightest of insights.
Thanks a lot!
Regards
Von: "Amit Kumar Saha"
Should it be more easy than writing e.g. a plug-in in Python?
HTH, Michael
The trick here isn't creating an extensible plugin. The trick is defining what "without much hassle on the part of the end-user" really means. Who's the end user? Joe Artist or Edward Engineer? Sven's granny or a bunch of kernel developers?
In general, making a piece of software extensible requires two main components: a grammer understandable by the core software and an API accessible through that grammer to core functionality. One problem you'll have to address is what parts of the API are visible to the plugins and what parts are not.
To make a piece of software extendable you could ignore the API portion and create a simple grammer that end users could use to essentially configure the plugin. Imagine a simplistic scripting language that simply sets a bunch of variables that the main plugin normally requires you to set manually using a series of dialogs or tabs. Wouldn't even require anything as complex as Perl or Python - it could just be a series of name/value pairs. But this isn't really extension, its configuration.
More complex examples would include exactly what GIMP already does with it's language extensions. You can load a dll easily enough or embed an interpreter like Perl or Python. But is programming in Perl or Python "easy" to your end user? A more common approach these days is to allow extension via XML. You can easily embed an XML parser into a plugin (I've used libXML2 in my plugins to save configuration data). But then you have to decide if writing XML by hand is easy for your users. Not to mention defining the XML Schema or DTD for the language. In the end, though, what you've done is create a new programming language. If you're doing that, and started with the intention of making it easy to use, you might as well use a well known language like Perl or Python instead.
You could provide a series of core features in the plugin that could be used in a reorderable stack and then build a GUI that used drag and drop to rearrange that stack. Sort of like arranging a series of existing plugins to be run in any given order. The plugin would then process in the order defined by the stack. The problem here is that you're simply providing a mechanism for using existing features, not allowing the user to extend that feature set.
So before you decide on the mechanism, you have to define who will use it and what you're really trying to allow them to do.
I'm not aware of any plugins that provide this though it wouldn't suprise me if someone had already done something similar. Plugin interfaces are a standard part of many applications these days but I think you'd be hard pressed to find any that don't require some level of programming expertise to use.
[snip]
As Michael mentioned, using a scripting language such as Perl, Python, or Ruby would be to do most things you might want to do. If you want to extend a compiled plug-in that is also possible.
Take a look at TinyScheme (used in the Script-Fu plug-in of the SVN version of GIMP). It has the ability to use run-time loadable pre-compiled extensions. The URL for TinyScheme is http://tinyscheme.sourceforge.net/.
The other scripting language plug-ins for GIMP also have ways to extend the base language. The hooks used to allow scripts to tie in to GIMP use them.
Karl Günter Wünsch wrote:
How about having a C++ virutal interface which you only have to fill in with your own methods and GUI elements in a set dialog interface... I have several things that I really would like to try and would require a native compiled plugin.
But since there is no sound C++ interface to the innards of the GIMP :-(...
There is no sound C++ interface for only one reason: nobody has written it yet.
It should be fairly easy, especially since the C library GIMP builds upon was designed specifically to be easy to write wrappers for (GObject).
- Martin Nordholts
Hello Michael,
Joe Artist comes closest :) I am targeting end-users who are primarily using the plugin to get their jobs done and if needed learn some bits and pieces to extend the functionality.
You are spot-on. Its not extending the features.
Artists basically.
Thanks & Regards
Hello Michael,
Yes. I am basically targeting end-users of GIMP,mainly GIMP. So learning Python for them might be not the best option due to variety of factors.
Thanks
Hello Kevin,
Could you please explain the "pre-compiled extensions"? Do you mean to say pre-compiled plugins loaded during runtime?
Please explain that in more details.
Thanks a lot
Hello all,
Here is another way I thought I could give some form of "extensibility" to a plugin user. Say, that I want my plugin to be a single entry point to all the Image processing operations possible with GIMP. What I do is display all the GIMP functions to the Plugin user via the Plugin User Interface(GUI). Then the user selects the operation that is to be performed and the plugin sets off to do the necessary job.
I am assuming here that the functions of the GIMP that I list for the user is only those for which there exists a API entry in the libGimp. In the background when the user selects a particular operation, the corresponding API function is called. This is of course an assumption to simplify the thought process.
Am i thinking in a way that could possibly be implemented? or is the word "extensible" remotely applicable to my idea?
Waiting for your comments!
Besides the scripting languages mentioned by others, you could also take a look at the MathMap plug-in if you are good at math...
MathMap home page: http://www.complang.tuwien.ac.at/schani/mathmap/
Nice examples of MathMap usage: http://www.flickr.com/groups/mathmap/
-Raphaël
Now your plug-in seems to become something I'd call GIMP. What use cases are you trying to handle, actually?
Regards, Michael
So what you're talking about here is a graphical interface to the API that a user can use to build his own extensions? Essentially, it's a graphical programming language. There are quite a few examples of these in the music world that allow the construction of modular synths (amongst other things).
It sounds to me more like a separate companion program that's used to construct plug-ins than a plug-in itself. I like the idea very much.
---AV & Spam Filtering by M+Guardian - Risk Free Email (TM)---
Em Qua, 2007-08-22 às 23:19 +0100, David Marrs escreveu:
Same with me; I would love something like a node-based editor (e.g. http://pupuedit.sourceforge.net/screenshots/pihlaja_04_04_2007.png and http://imaginit.rand.com/files/water_graph.gif )
This would let non-programmers, or programmers which aren't into image processing, create their own plug-ins.
Not only in the music world. Around 1993 or so, I remember using a
program called Khoros Cantata to design some image filters. A quick
search on the web returned this tutorial with screenshots of the old
X11 version that I used:
http://www.cse.psu.edu/~cg585/cantata-over.html
Just imagine that the glyphs (the boxes that can be connected) could
be the operations that GIMP offers through the PDB.
It seems that Khoros Cantata has been acquired at least twice by
different companies, has been ported to Windows, and is now sold as
Accusoft VisiQuest:
http://www.accusoft.com/products/visiquest/overview.asp
The interface has changed a bit, but it is still based on the same
ideas of connecting glyphs providing various functions.
By the way, this brings back some memories about what I did in 1993 as an exercise for a course in digital imaging. Students were asked to write a new filter for Khoros and use it to perform some interesting image transformations. I decided to write a filter that would use various correlation methods to reconstruct an image in which the lines were shifted horizontally by some random amount. The default method was optimized for "un-shifting" images at TV resolution (PAL) that were shifted by one of three predefined offsets picked at random. The method worked surprisingly well. The code and the results were presented to the professor. He asked if, by any chance, this could be used to decode Canal+ images (a pay TV channel that was popular in several European countries). And the answer was yes. Not in real time because the 486 processors that were common at that time were not fast enough, but the method worked well with recorded TV streams (sometimes even without using inter- frame correlations). Ah, I still have fun when I remember this and when I consider that the professor gave one of the top marks for this exercise.
-Raphaël
In some ways, this is essentially what /meta operations/ in GEGL is about, at the moment they are written in C, but they could just as well be created with an XML syntax and edited in a graph based environment. See GEGL (http://www.gegl.org/) and bug #465743.
/Øyvind K.
That looks similar to the types of things one can do with GEGL which is due to be integrated in to GIMP after the 2.4 release.
Hello Kevin,
I shall have a look at GEGL.
Thanks
Hi Raphael,
On 8/23/07, Raphaël Quinet wrote:
On Wed, 22 Aug 2007 23:19:30 +0100, David Marrs wrote: Not only in the music world. Around 1993 or so, I remember using a program called Khoros Cantata to design some image filters. A quick search on the web returned this tutorial with screenshots of the old X11 version that I used:
The link is dead.Any chance you have some docs with you?
Regards
On Sat, 25 Aug 2007 12:19:44 +0200, Amit Kumar Saha wrote:
Hi Raphael,
http://www.cse.psu.edu/~cg585/cantata-over.htmlThe link is dead.Any chance you have some docs with you?
Regards
google
Khoros Cantata
On 8/25/07, gg@catking.net wrote:
Khoros Cantata
That is the first thing I did when I got the dead link. One of the results I got was the dead Link. The others were about the commercial products that uses that concept of "glyphs". Though i got a vague idea of what it was, but more information is desired.
Regards
Most systems used for creating visual effects for movies are node-based, and have been for over a decade. Look at Nuke (http://www.thefoundry.co.uk/promo/nuke.html) or Shake (http://www.apple.com/shake/) for current examples.
The last version of the page (from Feb. 08, 2005) can be found at: http://web.archive.org/web/20050208090913/http://www.cse.psu.edu/~cg585/cantata-over.html
About half of the images on that page are missing.
Hi Kevin,
I was just having a look at GEGL gallery (http://www.gegl.org/gallery/index.html) applications. The concept of XML file to specify a pipeline of Image processing operations is basically clear to me. However I would like to know a few things:
1. It seems from the documentation that, I can specify the operations as a XML file as above instead of creating a DAG. How do i then use that file to apply the operations? What about error checking? What operations are supported?
2. Can I work with the individual pixels of an Image using GEGL? Say I want GEGL to work with only certain range of pixels of my Image, is it possible?
Thanks ,
You mean a certain area of your image, rather than all of it? You would do that using the 'crop' operation (and you would later layer the result on top of the original image with a 'clear' operation to clear the area, and a 'normal' operation to overlay the result)
Hi Kevin
Also, I would like to know, when GEGL is integrated into the GIMP, will it be available for the Plugins to access the GEGL as well?
Regards
The plan is that GEGL integration into GIMP will start after 2.4 is released and the 2.5 development cycle will be devoted to a process of gradual replacement, without changing the GUI significantly, thus 2.6 should be a version of GIMP that hasn't changed a lot of the GUI, but a development cycle that leads up to a GEGLified version of GIMP that can see further development and innovation.
According to the plan GEGL will replace all code in the GIMP that is accessing and or modifying pixels, some forms of GIMP plug-ins will most likely be entirely replaced by GEGL plug-ins instead. And as mentioned elsewhere in this thread, GEGL plug-ins can either be descriptions of graphs, or actual C code. Another option that should already be possible if someone is thus inclined, is actually to write a GIMP plug-in for GIMP 2.4 that allows GEGL plug-ins to be used directly by current versions of GIMP, this is less interesting than another bridge that will have to be written, which is a wrapper for (at least some of) the exisitng GIMP plug-ins to work from within GEGL, this will be needed to provide legacy support for some of the older plug-ins (these plug-ins will thus still work, but have limitations wrt bit-depth and such).
/Øyvind K.
Hello all,
My current work at hand will possibly require me to write a plugin for GIMP (current version) which will use GEGL for its image processing operations. So if I proceed, I shall let the list know.
Here a couple of more queries:
1. Does any of the developers here have some demo C code which takes in a XML file specification of the operations and performs the image processing tasks using GEGEL?
2. Can I assume safely that most of the image processing operations are "applying the same operation" to each pixel of the image?
Thanks
Looking again at the API there is the gegl_parse_xml() routine. There is an example of XML code being used to specify a set of operations to be performed as well as the execution of those operations in the gegl binary file (found in the gegl source tree).
I haven't tried this recently. I'm not sure what happens if there are errors in the input XML file. You may get either an incomplete GeglNode structure (ie. one not containing all parts of the input XML) or NULL. The API doc doesn't specify which. All GEGL operations can be used in an XML file.
I din't think it is possible to work on individual pixels of an image. Øyvind Kolås would be the person who could give you the more definite answer on this.
