python api leak
python api leak Campbell Barton 16 Aug 12:25
  python api leak Manish Singh 30 Sep 10:40
Campbell Barton
2007-08-16 12:25:17 UTC (over 18 years ago)
python api leak
was looking at the gimps python API, svn - gimp-pdb.c:311
GimpParam * pygimp_param_from_tuple(PyObject *args, const GimpParamDef *ptype, int nparams)
PyObject *tuple, *item, *r, *g, *b, *x, *y, *w, *h; GimpParam *ret;
int i, j, len;
gint32 *i32a; gint16 *i16a; guint8 *i8a; gdouble *fa; gchar **sa;
if (nparams == 0) tuple = PyTuple_New(0);
else if (!PyTuple_Check(args) && nparams == 1) tuple = Py_BuildValue("(O)", args); else {
Py_INCREF(args);
tuple = args;
if (!PyTuple_Check(tuple)) {
PyErr_SetString(PyExc_TypeError, "wrong type of parameter"); return NULL;
if (PyTuple_Size(tuple) != nparams) { PyErr_SetString(PyExc_TypeError, "wrong number of parameters"); return NULL;
--- snip
Notice that tuple is always created, but error values dont free, I think both "return NULL;"'s need a Py_DECREF(tuple); before them.
Manish Singh
2007-09-30 10:40:52 UTC (about 18 years ago)
python api leak
int i, j, len;
Py_INCREF(args);
tuple = args;
--- snip
Thanks for noticing, you are indeed correct. This is now fixed in SVN.
Next time, filing a bug in bugzilla with a patch for these obvious sorts of things would be much preferred.
-Yosh
